Trailer Bracket Wiring Question - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 2 Old 04-29-2013, 07:32 PM Thread Starter
Quoted: 10 Post(s)
2004 F250
Heres my problem.
Bought the truck used with what the PO says is the factory tow hitch.
He also had a 5th wheel mounted in the bed. But since that is all he towed with, he moved the factory harness into the bed.
Since it was already cut in the bed, I did not want to remove it. So I bought the T-wiring harness to also put the wires down at the bumper, since this is what I tow.
My issue is the bracket. I want the factory bracket to be installed. So I went to my local Dealer, and had them look it up.
Part Number- 5c3z-14A541-AA
But this does NOT fit onto my hitch. My hitch has no holes in the bottom of it to mount.
Here it is, but obviously upside down.
So I called the PO as I still had his number. And he said the bracket mounted to the rear bumper. But been researching for an hour now, with no luck.
Not sure if I'm not looking up right part or what, but I can not find this bracket.
Any help.
Thanks.
04' F250 6.0l
Engine
KC S2 Turbo, NADP Trans 5r(Billet Shaft, ARP Studs(All Other Goodies), Holders 175/30, Driven Diesel Reg Return, MBRP 4" Turboback, IDP SCT Tuned, PHP FICM Atlas 40, Sinister EGR Delete, Sinister Coolant Filter, Edge Insight CTS, KN Intake,Riff Raff Boots(Metal Pipes)
Suspension
Bilstein 1500 Shocks, Bilisten Steering Shock
Exterior
Recon Light Cab Lights/ Tailgate Strip, Rear Lights blacked out, 05' HD Headlights, 08' Taillights, 10' Mirrors
SRTchris is offline
post #2 of 2 Old 05-01-2013, 08:18 PM Thread Starter
Quoted: 10 Post(s)
Nobody knows which bracket I need ?
04' F250 6.0l
Engine
Suspension
Exterior
SRTchris is offline
