Appropriate tires on F250 for towing fifth wheel camper? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 8 Old 04-24-2013, 08:02 AM Thread Starter
First of all, this forum is great for do it yourselfers. I'm new to this forum so hopefully I'm posting this question in the correct section.
Ok, I'm buying back my 2003 F250 crew cab 2wd 7.3L powerstroke. We have a fifth wheel camper and the LT tires are expensive. Can the HT or AT tires safely be used on my F250 pulling our fifth wheel?
Thanks
richboss302 is offline
post #2 of 8 Old 04-24-2013, 08:04 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
look at the load rating when buying for towing not tread type...I have E range on my dually (I think so anyhow)
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 8 Old 04-24-2013, 09:56 AM
MDarrough's Avatar
Yea, what he said. The tread type or even the ply rating doesn't matter much, but the weight rating is very important. Make sure your tires can handle the weight of your truck and the camper.
GOOD INFO HERE
Mark
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
post #4 of 8 Old 04-24-2013, 08:07 PM
85burban's Avatar
lt stands for light truck as opposed to p for passenger. it has nothing to do with at or ht. they do not make anything over a 6 ply in a p rated tire so the answer is yes you need to have lt tires and i would stick with 10ply or load range E (every letter is 2 plys c=6 d=8 e=10)
85burban is offline
post #5 of 8 Old 04-25-2013, 06:05 PM
StarDriver's Avatar
Don't skimp on tires, it'll be no fun trying to jack up your pickup with that camper attached when you tire blows out.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #6 of 8 Old 04-25-2013, 06:09 PM
jesilvas's Avatar
Quoted: 2 Post(s)
An AT tire is all terrain; referring to tread style. Same with HT which is highway tread.
LT is for light truck. MT is medium duty truck, and HDT is a big rig.
You need a LT truck tire with what tread you feel you'll need. Most likely it's a load range E.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 8 Old 04-25-2013, 08:03 PM
85burban's Avatar
Mt is mud terrain
85burban is offline
post #8 of 8 Old 04-26-2013, 09:30 AM
SoCalPwrStrk's Avatar
I just put tires on my dually, Cooper Discoverer ATR, 10 ply E rated, i got them from Americas/Discount Tire co. im not sure what size you run, i got 235/85r16 for $118 ea. very reasonable price in my opinion.
"Big Truck" 1997 F-350 CC DRW 4x2 Cali model
Diamond Eye 3" dp to 5" straight pipe, DIY 6637 intake, Pillar gauges, 6.0 trans cooler, Intercooled, TS 6 pos. chip with TW Tunes, 1.0 Housing, Barder Billet Wheel, EBPV Delete
"Baby Truck" 1999 Ranger EC 5 speed 3.slow
Camburg Long Travel, Billit upper arms, Fox dual rate coilovers and double bypass in front, Deaver race pack w/ fox double bypass in rear, fiberglass fenders, 16x8 American Racing Mohave Wheels
SoCalPwrStrk is offline
Tags
fifth wheel , tires
