flatbed Pocket gooseneck ball - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 3 Old 04-15-2013, 05:48 PM Thread Starter
Underpowered's Avatar
anyone have any pics of how their pocket gooseneck ball is set up under their flat bed.
I need to put one on my truck, just not sure if welding it to the current flat bed cross members will be sufficient or if i need to direct frame mount it under the flat bed. I plan on fabbing it all up myself.
'89 K5 Trail Rig--not at all stock
'98 Jeep ZJ DD-nearly stock
'00 F350 Tow Pig- bone stock.
Underpowered is offline
post #2 of 3 Old 04-15-2013, 08:13 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Be safe and mount to the frame rails
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 04-20-2013, 04:01 PM Thread Starter
i know that is the 100% best way to do it, but i want to know on flat beds IF they are mounted to the bed or frame. I think the bed is more than stout enough to handle it, and if it is how some come from the factory i would feel safe in doing mine that way as well.
after seeing how some factory made bolt in kits are made to add a gooseneck/5th wheel setup to a truck, i don't see why i could not bed mount it. heck, on a buddies 2500 dodge the gooseneck ball clamps on the frame, not a single bolt through the frame, just 4 clamps around it. i would think anything i would build would be at the very least as sturdy as a few frame clamps.
