what brake controller - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 18 Old 03-23-2013, 10:38 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
getting ready to start taking the fifth wheel out and just need to know is there a good or bad brake controller(besides one that doesnt work) any brands to stay away from and how hard are they to wire up to the truck I have a 04 f250 thanks for the help
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #2 of 18 Old 03-24-2013, 05:33 AM
motorman173's Avatar
Thumbs up
I just upgraded to a Tekonsha Prodidgy P3. They are top of the line from everything I've read.Instalation is pretty straight foreward.
2004 F350 CCLB 6.0 Sinister Coolant Filter, EDGE Evolution for Monitoring, Blue spring Mod, Zoodad Mod, Ficm Repaired, EGR Deleted, Updated Turbo Feed and Drain Pipes, Straight Piped, 08 trans pan and filter, 08 Dif cover, NUC oil Bypass Filter, Pro Vent CCV Filter
motorman173 is offline
post #3 of 18 Old 03-24-2013, 05:56 AM
Send a message via Yahoo to bfast54
I agree on the Prodigy, it's what I run, and ....you should have a plug , under your dash, not the SCAN plug...............and buy the Ford plug to Prodigy pre made cable, and just plug it in. The cable should be right at the Prodigy didplay.
If your truck came with tow harness....................most do now days. You may need to add a fuse, if you have not used the harness plug yet, or no one else has.
bfast54 is offline
post #4 of 18 Old 03-24-2013, 09:43 AM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
How much is that. Are there any that you guys have heard to stay away from. About how much is it to install the hitch in the bed?
04 f250 cc sb.
jmeaby is offline
post #5 of 18 Old 03-24-2013, 09:44 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 952 Post(s)
Feedback Score: 6 reviews
I say go for the Prodigy P3 as well.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #6 of 18 Old 03-24-2013, 09:50 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Depends on what hitch you want in the bed.
If you want the common Reese 30035 rail kit, I usually take 3hrs on average to do one.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 18 Old 03-24-2013, 12:34 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
We have the hitch just need to buy the rails for my bed.
04 f250 cc sb.
jmeaby is offline
post #8 of 18 Old 04-14-2013, 12:08 AM
I bought a P3 to replace another brake controller. Should be hooking it up in the next week to compare
alradco is offline
post #9 of 18 Old 04-14-2013, 12:26 AM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
I'm still looking for a place to install 5th wheel hitch my best quote was 550 just to have rails put in....
04 f250 cc sb.
jmeaby is offline
post #10 of 18 Old 04-14-2013, 08:08 AM
jesilvas's Avatar
Quoted: 2 Post(s)
For me to put em in would be about 460. So maybe they are doing something else?
4R100, 2wd
330,000 + miles
jesilvas is offline
