Twin turbo setup on 97 7.3L - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 6 Old 03-21-2013, 01:38 PM Thread Starter
I upgraded my turbo but am wanting more. I'm trying to see what gains a twin turbo setup on my 97 7.3L will gain me for towing. I pull a 24' steel horse trailer, usually loaded down with 7 or 8 horses and would like a little more out of the truck. I have an after market intake, 6 stage ts chip, upgraded turbo, and heavy duty torque converter. I love the performance when I'm not pulling a trailer but when pulling 26 to 30,000 lbs. I cant help but want a little more power. Any suggestions?
7.3 coal roller is offline
post #2 of 6 Old 03-25-2013, 08:26 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Injectors, hpop, custom tunes, and a d66, if your dead set on twins everything has to be custom and I don't think anyone makes a kit for the obs 7.3L good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 03-25-2013, 09:35 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Won't gain you anything except a lighter wallet.
CT Performance, Inc. is offline
post #4 of 6 Old 03-25-2013, 10:14 AM
Tj Krawler's Avatar
Sounds like you just want a little more power. If you already have a bigger turbo, you could throw some 160/100's or so in it with custom tunes. Assuming you already have gauges and an exhaust. With a good TC and VB in the trans, it should hold. You will probably need at least a 17* HPOP as well.
I wouldn't go with twins unless you want 600hp+. A good single setup will still spool fine and cost a lot less.
I hope you mean 26-30k combined. Even that is a lot of weight. If you do mean 26-30k of trailer... You need a bigger truck.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #5 of 6 Old 03-25-2013, 06:08 PM
StarDriver's Avatar
Yes, buy this.
http://www.truckpaper.com/listingsde...x?OHID=3977066
Don't forget, pulling it is one thing, STOPPING it is another.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #6 of 6 Old 03-25-2013, 07:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Damn that thing is nice, wish it wasn't as expensive as a new home lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
