SRW or DRW??? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 15 Old 02-25-2013, 01:13 PM Thread Starter
Unhappy SRW or DRW???
Hi guys,
New to forum here and appreciate any/all input. I currently have '01 7.3l f350 crew longbed 4x4 with SRW, 675k mi., with significant rust/rot issues. Unfortunately injectors not working w/ cold weather, need replacing @ +/- $2k. With that in mind, I was considering a DRW that is for sale locally at a very reasonable price as a replacement. It is also an '01, 7.3l f350 crew longbed 4x4, with 250k mi, but extremely clean body and frame for age.
I have recently begun using my SRW with a 14K trailer for transporting my 8k lb skid steer to sites, harvesting hardwood logs, and taking down old barns to reclaim the lumber off-road in the mountains of WV. The SRW has performed great both on-road and off-road for these tasks even with muddy conditions back woods. I know the DRW would provide even better road hauling performance, but I am concerned how it would do in muddy off-road conditions??? I have never had DRW and could use all the informed opinions you can offer on this application. The last thing I want to do is go from the frying pan of my current engine issues to the fire of trying to use a DRW for the wrong application.
Sorry the post is long, but I wanted you to have whole picture. Also, if this is not the right place for this post, please tell which forum would be more applicable.
Thanks in advance for your advice, greatly appreciate it,
Brian A
muskie36 is offline
post #2 of 15 Old 02-25-2013, 04:12 PM
jesilvas's Avatar
Quoted: 3 Post(s)
In my experience, I wanted duals up front and singles in back
The reason for that is that my front is heavy. Stock tires too, so not very wide. Lots of weight, and not a lot of tire surface area equals more PSI on tires touching ground, and easier to sink.
In the back, it's dead opposite. Lightweight, lots of tire. So it didn't sink, but floated on the mud almost and couldn't really grab anything with the tires.
However, if I had plenty of weight on the rear, I think I'd be ok. Haven't tested it yet. I think that weight BEHIND the rear axle would even be better. You'd take weight off the front and transfer that to the rear, in addition to the extra you added.
I'm also using Hankook Dynapro ATm's. Fairly aggressive, just not "mud" tires. That might help too.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 15 Old 02-25-2013, 04:18 PM
Re: SRW or DRW???
I have never owned a DRW but I know a lot of guys that do. They all have the same opinion as him^^^^. Without any weight on the rearend they will get stuck on wet grass on any slight incline. If you put some weight back there it will do better. Some Toyo M/T's or similar may help.
Sent from my GT-P5113 using AutoGuide App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #4 of 15 Old 02-25-2013, 04:19 PM
Tj Krawler's Avatar
675k miles... Nice.
I don't think it would be a problem. You might want to have a little more aggressive tire, at least a good A/T.
I've been in a situation where my DRW did better than a SRW would have. Grass was a little soft. I had ~3k pounds of brick in the bed. I'm positive a SRW would have broke through the grass. Sure I left some decent tracks in the lawn, but I didn't break through.
If you get a DRW and don't like how it does, I'm sure you could find someone who would trade parts to change it out to SRW.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #5 of 15 Old 02-25-2013, 05:01 PM
6.0f250firstcar's Avatar
Yeah I'd go with a DRW
Ryan
6.0f250firstcar is offline
post #6 of 15 Old 02-25-2013, 07:02 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
could get a SRW and put larger tires/wheels on it
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #7 of 15 Old 02-26-2013, 07:07 AM Thread Starter
thanks so much for the input you guys. if i were to take advantage of buying this DRW for the great shape of motor, trans, body & frame, what would the rough costs be to convert it over to SRW? The rear in my current SRW is fairly newer replacement from a donor, so would this changeover be somewhat of a direct mechanical swap out or rears with not much else involved, or does it become a major and costly project?
muskie36 is offline
post #8 of 15 Old 02-26-2013, 09:37 AM
Why not just keep it a DRW?
Ryan
post #9 of 15 Old 02-26-2013, 09:47 AM
mattdoxa's Avatar
Re: SRW or DRW???
Not positive but i would think the dually has different gearing typicly 4.30,4.33. So ud need to swap diffentials to use 4wd.
Sent from my C771 using AutoGuide.Com Free App
06 king ranch dually. 4" silverline duals, sct x3 tuned by tony wildman.
arp studs rcd egr delete updated fpr 6.4 banjos warren 175/stock. stage 1 from mtw,
mattdoxa is offline
post #10 of 15 Old 02-26-2013, 02:38 PM
jesilvas's Avatar
Quoted: 3 Post(s)
F350 dually's are usually 4.10s. Idk if they made them in 4.33 or not.
F350 SRW could be 4.10 also
4R100, 2wd
330,000 + miles
jesilvas is offline
