Originally Posted by muskie36
thanks so much for the input you guys.  if i were to take advantage of buying this DRW for the great shape of motor, trans, body & frame, what would the rough costs be to convert it over to SRW? The rear in my current SRW is fairly newer replacement from a donor, so would this changeover be somewhat of a direct mechanical swap out or rears with not much else involved, or does it become a major and costly project?
It might be cheaper if you are saving the old truck. All you need is a new bed (DRW bed has the wheel openings cut different) and a set of SRW wheels. Pull the spacers on the front axle, bolt SRW wheels on. The rear axle will be ~1.5" wider than the front, but everything should bolt on fine. You could swap the Dana 80 for the 10.5 in the truck you have now, if the gears match. I personally would leave the DRW axle under the back. It's a stronger axle, and its that much less work. Hopefully the DRW has a limited slip in it already. If not... you're going to want one.
Originally Posted by mattdoxa
Im pretty sure mine has 4.33 not sure tho
Sent from my C771 using AutoGuide.Com Free App
What's your RPM at 60 and 70? With stock sized tires and 4.30s, 60 will be ~2,000 RPM. 70 will be ~2,350 RPM. 4.10s will be ~100 RPM less.
Originally Posted by jesilvas
On an 06 that's possible, but being an 01 I'm almost 100% sure that wasn't an option.
I have 4.30s in my 2000.
But to be fair, I've never heard of a 7.3 with 4.30s either... Maybe the PO put them in...
