Just asking dont rip me a new one - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 10-06-2012, 12:03 PM
dpt dpt is offline
Is it possible to remove the third 7,000lb axle from a 3 axle trailer to reduce the GVWR from 21,000 to 14,000. The big question would it be legal? Just asking. Thanks for any legit input.
Old 10-06-2012, 01:06 PM
Yes you can. I've done it twice.
Old 10-06-2012, 01:19 PM
check with your dmv. in tx if it is a manufactured trailer the registered gvwr is what the mfr specified on the mso. ya gotta get it inspected and signed off on if ya remove an axle and want to lower the gvwr.
Old 10-06-2012, 01:44 PM
Mine was a take 3 wedge trailer. My pap is good friends with the owner and had them send us a new vin tag and title. Here in pa it was easy to have it all switched.
Old 10-06-2012, 02:19 PM
In va you can register it to hall under the weight that is recomended. I did so on a simi i use to own. Then got the free blanket overweight permit that allowed me to go back to hauling the weight. Just dont get caught with your overloaded trailer. Big big fine.
Sent from my iPhone where spell check hates me.
Old 10-06-2012, 04:31 PM
dpt dpt is offline
Now that I havent been ripped a new one for asking. I found a 38ft goosenck but it has a GVWR of 21,000 and I need it at 14,000 to stay out from under the CDL thing.
Old 10-07-2012, 05:33 AM
main thing is you will need the dmv to inspect it and issue a new gvwr tag for it after your done. A lot like if you build a homemade trailer.
Old 10-08-2012, 05:36 AM
You can do what you are asking but it is not necessary. You can have the GVWR lowered without removing the axle. This would be done from the trailer manufactuer or a truck upfitter, not the DMV.
Old 10-08-2012, 05:43 AM
Yeah but with one less axle you have two less tires to buy and two less bearings and brakes to worry about.
Old 10-08-2012, 05:45 AM
+1. The DMV cannot do anything for certifying/de-certifying the capacities. Get with the manufacturer and you're set.
