Equal-I-zer brand wd - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 3 Old 09-04-2012, 07:02 PM Thread Starter
mechanix's Avatar
I have a Drawtight brand WD hitch setup right now it doesn't seem to be getting the job done as much as I would hope it would. So with that said what are your thoughts and opinions on the Equal-i-zer brand of WD hitches ?
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
post #2 of 3 Old 09-06-2012, 03:33 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I ran the Equalizer WD bars when i towed bumper. The ones with solid connecting bars. The setup worked amazing and cured sway. I remember it could get a bit noisy if backing up into the campsite and turning hard, probably should lube them once in awhile and I did not. its just metal on metal under force, so the noise is to be expected. The setup worked great, I have recommended it my best friends with bumper pulls and would buy again in a heartbeat if I had a bumper pull sway problem.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 3 Old 10-07-2012, 09:03 AM
Garage
IMO, it is the best hitch for the price. I have had mine for years. I tow a 30 travel trailer behind my ex. the sway control can not be beaten with this setup. Although it is a bit noisy, just spray WD40 on where the bar sits and on the bar. You need to make sure you set the bars up correctly.
Robs97z28 is offline
