Trailer tires? What do you use? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 23 Old 08-01-2012, 06:16 PM Thread Starter
44magnum's Avatar
Quoted: 2 Post(s)
Question Trailer tires? What do you use?
I need to replace my tires on my little bumper pull, 225/75-15's Radials. load range "D" my trailer has a 10K gvwr. Right now I have whatever off brand tire (towmaster?) my old shop recommended but they aren't holding up well, I have had 2 sets now (I don't remember what brand the first ones were, but they were different) and twice (once on each set) I have had a belt fail. I keep them aired up to the max 65psi. Thing is, I go the speed limit when its safe to, IE 70-75mph. And all the trailer tire I have found in that size are "st" and are not speed rated, meaning max speed 65mph. My local tire dealers now carry Goodyear Marathons. So what do you guys recommend and use? Do you guys go over 65?
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #2 of 23 Old 08-01-2012, 06:29 PM
Rexter's Avatar
i have always run douglas (walmart) radials on the 7x12 i just sold.
225-75/r15 on a 3500lb axle. i maxed it a few times hauling a yard of dirt and a cord of wood. tires are rated for 1874 lbs each. the trailer made lots of trips from tx to fl and ar with 1500-2000 lbs of motorcycles on it. always run 70-75, even 85 coming back from ar with no issues. i didn't run over 36 psi.
loaded and ready to roll.....
Rexter is offline
post #3 of 23 Old 08-01-2012, 08:37 PM
JSchuricht's Avatar
Michelin LT's E rated on a 16" rim. I started running 70mph as soon as I left CA and realized that all the 55mph trailer speed signs were gone.
JSchuricht is offline
post #4 of 23 Old 08-01-2012, 11:23 PM
WD40's Avatar
Quoted: 39 Post(s)
Check your Michelin, they may only be rated for 65 or 67 MPH.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #5 of 23 Old 08-01-2012, 11:27 PM
JSchuricht's Avatar
Their truck tires, should be around 90-110mph. IIRC their the same as what I have on my 95, just a different size.
post #6 of 23 Old 08-02-2012, 04:27 PM
StarDriver's Avatar
If you have a Discount Tire nearby, they usually carry Carlisles, get the Load Range E and buy the certificates for them.(Road Hazard, free repair.) I run them on my 24ft and run the 235-80-16s on my big trailer, I've only paid full price for a tire in 4 years. Love replacing $20 tires. But I will tell you this, SPEED is a killer of any of those tires, keep it to 65 and watch your tire pressures and you will be fine.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #7 of 23 Old 08-08-2012, 05:31 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Bridgestone Duravacs best trailer tires for heavy, heavy trailers. expensive and may be overkill for your setup. search on the big trailer forums, Duravacs top 3 for those who haul heavy.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 23 Old 08-09-2012, 04:50 AM
225/75 15 Maxxis is what I use. They have been on my toy hauler for about a year now. I drive between 65 and 70 with the trailer.
race735 is offline
post #9 of 23 Old 08-26-2012, 04:27 AM
I have Michelin XPS RIB E rated tires....unlike trailer tires, they have a very stiff sidewall....so they arent like balloons on the road...tougher for tight turns though...i just take my time.
spinto is offline
post #10 of 23 Old 08-26-2012, 04:55 AM
2000superduty's Avatar
Garage
I run the goodyear marathon's on my 5th wheel. 225/75-15 load range D is what is on there now but they make the same size in a load range E.
00' F350 Lariet, CC, 4wd dually, 7.3L, diy intake, superchips, autometer gauges, 4" diamond eye.
2000superduty is offline
