| What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers |
Trailer light wiring issue
I've recently bought a 5x8 utility trailer, and I'm having trouble getting the lights to work. With a test light grounded to the metal plate on the bumper, I can find the two turn signals and the brake lights in the 7 pin connector next to my reciever hitch, but once I put the 4 pin adapter on I have no trailer lights. Also, the black wire with a white tracer that comes out of the back of the 7 pin connector is cut, and spliced to another wire that isn't connected to anything. Should I splice the cut wire back together? The truck at one time had a 5th wheel hitch, and there was another connector in the bed. I removed it when I swapped beds, and although I haven't tried, I don't believe my trailer lights have worked since.
Any ideas? |
the black should be the power supply for a break-away kit. the white wire is the ground, and should be connected to a ground point.
No white wire that I can see, just a white stripe on a black wire. When I hooked them up to our explorer, my turn signals illuminated all 3 led indicators on the adapter, but no turn signals or tail lights on the trailer. After splicing the black wire back together, I think I'm going to end up re-wiring the trailer.
verify this on the back of the truck... and i would rewire too. it is cheap and quick.
here's a good diagram too
Thank you much, I'll see what I get. I sure hope I don't end up having to take apart the wiring at the back of the truck. It's a rats nest now, lots of splices.
Not necessarily a break away. Just a 12V charge line to run whatever you want. |
here's a good link for wiring. colors chart included. Trailer Wiring Diagrams | etrailer.com |
4way, 5way
Green - Right Yellow - Left White - Ground Brown - Running Lights 7way Green - Running Lights Brown - Right Red - Left White - Ground Blue - Brake Black - 12V charge line Yellow/orange - reverse usually |
different mnf can use diferent colors for back-up and 12V power, (some use purple and red)
however these should always be the same for both 4 and 7 wire, green = right turn/brake yellow =left turn/brake white = ground brown = running lights |
