Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > What a Powerstroke is for, Towing and Hauling
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 10-06-2007, 05:20 PM
159060 159060 is offline
F-250 vs F-350 towing
Does anybody know if a F-350 would tow better? Both are rated by Ford to be able to tow 12,500#
Old 10-06-2007, 05:27 PM
robertcarmel robertcarmel is offline
Big Daddy!
They are rated at 15200, or 15700 depending on configuration(5th wheel).
There a lot of things that make differences
Dually give more traction, and more stability, but not necessarily more wieght.
The rear axle makes ALL the difference!
3:73,4:10, or 4:33 (only available in one version of the F350)
For a MAX towing rating of about 18000 pounds!
Bob~!
Old 10-07-2007, 04:07 PM
Thanks, let me elaborate a little. I am replacing my 05 F-350 6.0 SRW regular cab. I have to choose between a 250 or 350. I tow construction equipment every day (conventional) 5th wheel is not an option. Dually is not an option. Generally I'll have 5 to 6 tons behind my truck and when my 6.0 is running right I'll gain speed uphill, with no sway above highway speeds. I just want to know if I'll loose some stability by dropping to a 250.
Old 10-07-2007, 04:46 PM
nccatfan nccatfan is offline
Send a message via AIM to nccatfan
Well, it's not an issue of power. It's all in the frame and gearing. I've seen these engines put into straight-trucks/vans hauling up to (and maybe more than) 30,000 lbs!
Old 10-07-2007, 04:52 PM
The straight-trucks where I work weigh 12,500lbs. empty! They run DT466 engines (7.6L)
Old 10-07-2007, 05:02 PM
97stroker_roalin_coal 97stroker_roalin_coal is offline
if you special order a f250 you can have it set up just like a 350 but the 350 you can have tax write off woth fueal and stuff because its a construction truck
Old 10-07-2007, 05:19 PM
720Deere 720Deere is offline
If your towing that much with a bumper pull trailer you will be better off with a 350. I would imagine that a 12,000 lb trailer is going to put enough load on the truck that overload springs will be necessary. You are also going to need the extra GVWR to be legal.
Old 10-07-2007, 05:25 PM
Maintain Maintain is online now
<-- 13.0 @ 102 launch
Send a message via AIM to Maintain
Depends upon the spring package that comes with your truck. I have the "camper package" on my F250... and I have the same 6 pack of springs that my friends dually has. It's actually 5 springs and an overload.
5tons = 10,000lbs and 6 tons = 12,000 lbs. Is this including the trailer or just the material?
I've had a GCVW of 17500 (my truck weighed right at 7500lbs at the time) and that was bumper pull - my truck hauled it just fine...
Old 10-07-2007, 05:34 PM
Diesel Freak Diesel Freak is offline
Rice Hunter
Ditto to MAintain!! They're gonna pull the same. Tongue weight is what's gonna hurt you unless you have a trailer package as maintain states.
Old 10-08-2007, 06:57 PM
Smile
Thanks guys, GCVW is around 14 to 14.8k. Just traded my 05 F-350 on an 08 F-350. Couldn't bring myself to drop to a 250. Camper package is the key, you can see where my 05 uses the aux. springs. Hope the 08 diesel is better than my 05 6.0. I'll let you know how she pulls
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
