how do i tie down a truck? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 9 Old 06-15-2012, 08:35 PM Thread Starter
my buddy's 6.0 is ready for bulletproofing (EGR went today) and i need to tow it to CT on the deckover. Whats the best way to tie it down? pics would help a lot. all i know so far is to do a cross pattern on the front and back. any input appreciated.
blakerugg is offline
post #2 of 9 Old 06-15-2012, 09:56 PM
spool up that turbo!!
hollister25073's Avatar
Just around the axle is fine as long as your not pinching brake lines or anything else
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
boost pyro and engine oil temp
AIH delete, hpx, frx
05 harleys 8000k's
billet grille and painted shell
17"welds and 35-12.5's toyo mt's
cab lights
southbend con ofe waiting to go in
fresh 7.3 from reviva
SOLD
1995 f150 302 5spd 35's sad sad day
hollister25073 is offline
post #3 of 9 Old 06-15-2012, 11:04 PM
countryraised's Avatar
around the axles is best. tying to the truck itself allows the chains or straps to get loose and tight and work around or pop loose as the truck will bounce when the trailer hits large bumps no matter how tight you ratchet it down.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
post #4 of 9 Old 06-15-2012, 11:13 PM
dieselmatt's Avatar
Quoted: 4 Post(s)
I saw a car hauler put straps around each tire. Thought that was interesting.
Sent from my ADR6350 using AutoGuide.Com Free App
dieselmatt is offline
post #5 of 9 Old 06-16-2012, 01:26 AM
JSchuricht's Avatar
Get yourself some good axle straps.
JSchuricht is offline
post #6 of 9 Old 06-16-2012, 05:44 AM
StarDriver's Avatar
The ones that go over the top of the tire are good, the slings don't hold the vehicle as well.
Summit Racing has nice ones.
Make sure the trailer you're putting the truck on is able to carry the weight. don't be like the guy on here who put a crew cab dually on a trailer rated for 7000 lbs, then put the truck too far back and ended up in the ditch.
You can use an X pattern or as long as the straps pull at an angle, the vehicle won't move.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #7 of 9 Old 06-16-2012, 01:30 PM
Yeah wheel straps are nice but not good on a heavy truck unless you get some designed for bigger tires
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
05 harleys 8000k's
cab lights
SOLD
post #8 of 9 Old 06-16-2012, 01:46 PM
elrojo63's Avatar
Chains around the axles just dont break a brake line
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
post #9 of 9 Old 06-18-2012, 06:20 PM
tire straps work
jsstrans384 is offline
