Originally Posted by Blue01F250
I like the 2nd option! But good luck with whatever you choose to do
I actually went with the first option, the new sleeve, and it's been smooth hauling since. The sleeve installed in about 5 minutes and works great, I just wish that the base was slightly wider as my Holland/Brinkley hitch has plenty of surface area that isn't being used anymore (the kaufman's fifth king pin base covered more).
Originally Posted by BigGreen06
I have a similar question, I'm looking into getting one of those Goosenecks w/ the turnover ball, mainly because I want to have a more stable trailer on the highway because what I'm hauling is heavy and awkward and I also want to have full use of my bed when I'm not hauling, and the rails that goosenecks or 5th wheels use are ugly IMO and take up some of that useful space. I got a price of about $575 for a hitch installed in my bed. Is this a good price? And also what are some opinions on that setup?
Thanks.
-BG06.
BG06, I know you're sold on the Goose neck idea but if you plan on hauling often, I'd recommend a fifth wheel for it's ease of use and quick connections.
I purchase and had my own hitch installed by the owner of Hitch Crafter of Lexington North Carolina...yes I drove down there.
They also carry gooseneck setups as well as air ride suspensions for everything...which I should have purchased.
Here's the exact hitch that I have and it is removable but no where near as simple to pull out as some goose neck options.
Hitch Crafter
Originally Posted by CHenry
they sell a sleeve for the gooseneck trailer that has a kingpin in the end of it - replaces the sleave that you already have...unless yours is welded solid.
thanks, already know about it and bought it. check out the first post for the links to the item that I did end up buying.
