| What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers |
Identifying my Hitch rating
Greetings,
I have an '03 F250 7.3 with what looks to be a factory installed hitch. I'm trying to identify the rating. There are no stickers left on the hitch. The only identifying mark is a small, stamped number 4. I'm assuming that it is a class 4 hitch but that would possibly be an expensive assumption for me to make. Any pointers on identifing the rating? Steve |
Well, on my F350, I have a Class III. So I doubt it's a Class IV.
It should be a class IV 2".
My F350 with tow package came with the class V 2 1/2" Even our 1500 suburban has a class IV hitch This gives an idea on your maximums, but there is a range between each classes of hitches(the ford factory hitches may vary slightly in weight ratings but are usually close) http://www.reeseprod.com/content/dow...er_Hitches.pdf Hope this helps |
This was helpful. Any thoughts on how to actually determine the rating by the design of the hitch, markings, etc?
Steve Quote:
You could maybe call the dealer with your vin and see if they can give a part number of the hitch if it was factory. if not take it to a trailer store that sells hitches and ask them if they could identify it.
Without markings youre just guessing. |
my 350 has a class v with a 2 1/2" reciever. (how big is yours)
bailey |
I have an 06 f250 with 2". Mine factory is 600lbs tounge weight and 6000lbs trailer towing. Then with a Weight Distribution hitch it goes up to 10,000. Etrailers sells a curt hitch wich is rated up to 15,000lbs for $240 with free shipping. Im looking at replacing mine real soon.
My F350 duallie has a Ford Factory hitch which is clearly labeled as being for up to 12,500 lbs w/ weight distribution, it's also got 11,500 GVWR on the door. The sticker said it had an HD towing package.
My '04 F250 has the factory hitch rated at 12,500lbs. Do you have a pic of it that might help determine if its a factory hitch or aftermarket? All of the trucks I looked at before I bought mine had the factory hitch on them were rated at 12,500.
