Pictures Of Air Lift & Dual control Valve Installation - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 05-05-2012, 10:48 AM
The job took me about 7 hours, I know - sounds like a lot of time. I was being careful not to kink the lines since they are run through the firewall and under the truck.
With the kit installed, I do have an air leak. There are many connections/fittings to check. I checked yesterday with soap & water in a spray bottle. I did not find anything. I am loosing 10psi and hour. Here are the pictures of the end result. The only part I did not install was the auxiliary fill line. I guess this would be good to have if the pump would ever fail.
I Installed this on a 2012 F450 4x4 Lariat.
Old 05-05-2012, 01:39 PM
Firefighter Member
looking good
