| What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers |
2008 F-450 has a GVWR of 14500. Ford says it has a GCWR of 33000.
Trailer has a GVWR of 25900. Would I add this up as 8800 truck (actual weight) 9800 trailer (actual weight) + load on trailer = GCWR? Or is it 14500 + 25900, which has me at 40400 before I even put something on the trailer? I've found this: Quote:
8800+9800 is ur dry weight. subtract that from the 25900 and 14500. but also make sure ur not over on any single axle either |
Understood, but this is where I'm getting hung up.
As far as legality goes with the CDL license.....if I pull onto a scale, with say my truck 8800, my trailer 9800, and a 7000lb load - the scale will read 25600lbs. Does that mean I do not need a CDL because my GCWR is under 26001...... Or I need a Class A CDL because the GVWR of truck + GVWR of trailer is 40400? Do I need a CDL Class A to even drive this trailer home from the manufacturer? |
Legal issues vary by state. In NC if I have a trailer weighing over 10k loaded or unloaded I need a class a cdl. If the truck is gross weighted over 26k I need a class a cdl. Most people here with good sized 3 horse trailers, legally have to have a case a cdl.
gcwr is pretty easy to configure here is mine as an example, my gcwr is 20k btw
my truck weight + weight of load carried= gcwr<20,001 my gvwr is 8800, so as long as i do not exceed 8800 truck weight combined with tongue weight of trailer i'm good, and as long as the truck + the trailer weigh less than 20k combined, and as long as the rear axle is not over it's weight rating i'm good at least that's how i understand the law, and my Ga driver's license says i can drive anything weighing under 26,001 lbs w/o any kind of extra requirement, 9/10 times if your commercially hauling then yes you will need a CDL though being as how it is a commercial drivers license, good luck and i hope i can read correctly and that i am informative |
In my case....I am looking at a trailer that weighs about 9k lbs but has a GVWR of about 15k. My truck is rated at 9900 GVWR and 20k GCWR. This means that the maximum LEGAL trailer GVWR I can tow is 10,100lbs. It doesn't matter what the ACTUAL weight is as far as the law is concerned (assuming you don't break the individual GVWR of either the truck OR trailer), just what the placards with the ratings say. Individual states can have stricter requirements, but that is the way the Federal law works. Clear as mud? -Aaron |
![]() -Aaron |
Jr |
Only in CA.
