| What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers |
Weighed the truck, lighter than I thought
So I finally got around to getting my weight at the local CAT scales since I got a Gooseneck 4 horse+LQ trailer and I wanted before weight to see how much my flatbed is gonna end up weighing.
Empty/full tank Axle......Rating.....ActualW.....remainder Front....5200........4420.........780 Rear......6830.......2860.........3970 Truck....9900.......7280..........2620 Truck & trailer empty Axle......Rating.....ActualW.....remainder Front.....""...........4480.........720 Rear......""...........4100.........2280 Truck.....""...........8580.........1320 Trailer....12000.....5340..........6660 Gross.....23000.....13920........9080 It inspired some questions....My rear axle weight gave me practically 2 tons instead of 1. And my GVWR-GVW is more than a 11/4 ton (which should be a F450 right? Does the GVWR of the truck go out the window and you just go by GAWRs/GCWR of the combo when towing? Say this setup: Front-5000, rear-5500, trailer-11,000......Truck is 10.5K, and GCW is 21.5K. All axles are under they're GAWR, the combo is under both GCWR & the 26K CDL limit. Should be safe. Last edited by jerg_064; 04-06-2012 at 11:48 AM. |
Yes, the GVWRs are sticker ratings for both the truck and trailer. Why do you think the truck should be higher? The "Gross" implied GCWR, that's why the header of that block says 'Truck & Trailer' and it's listed after the truck and trailer weights/ratings.
The nomenclatures are still pretty close on for GVWR, even all our new 2.5/5tons indicate about if not exactly that much weight on their door stickers. Got it on the end, stay under both...Kinda rediculous law. I may have made a mistake on the GCWR, maybe not. It's interesting that Fords GCWR/tow ratings charts changed from 20K in '04 and before to 23K in '05 (for my setup), yet the charts themselves do not list model years. They only list Model, gears, engine. So did they up the rating for all 6.0 powerstrokes, or did the '05-'07 get brake upgrades or something? They did get bigger rims so it seems plausible. |
