towing with a 7.3?? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 03-02-2012, 04:02 PM
towing with a 7.3??
Hello, I have a 2002 7.3 4 door long bed with 75K on it. I have been pullin my 32’ 5th wheel toy hauler with no problems at all. I hit the scales the other day with an empty truck (1/4 tank fuel) and an empty 5th wheel. Front axle was 4740lbs rear axle was 5360lbs and the trailer axles were 8720lbs. So im sittin at 18820lbs empty with my current set up. Loaded I can prob add 2K to that and the truck performs great, accelerates, cruises and stops with ease.
I am currently looking at a new 5th wheel toy hauler and it specs out at 13400lbs dry and max loaded at 18K. I do have air bags and a digital brake controller. Any thoughts on pulling the trigger on this new hauler? Can I tow this thing with my truck? I cannot buy a new truck at this time. Thx!!!
Old 03-02-2012, 04:26 PM
Your truck will pull it. Just make sure to watch your EGT's and trans temp.
Old 03-04-2012, 02:17 PM
truck will be just fine. as said watch you temps and your good. also keep the trailer brakes working.
Old 03-04-2012, 02:27 PM
Just watch the Temps 7.3 in my opinion is one of the best engines out there especially when it comes to towing.
Old 03-05-2012, 05:28 AM
it will tow it fine. with my f-250 i have towed a 37' trailer with a f-450 on it and it did great. the trailer and truck weighed around 19,000 plus my f-250 at 7900
Old 03-14-2012, 09:14 AM
how is that true Cool trans cooler work?
I see you have the 6.0 cooler on yours. I am looking to do the same. Do you have any pics of it done inline like yours? Thx
Old 03-14-2012, 09:18 AM
Im also considering swapping in some 4.30s to help tow the extra weight. Do ya think this would be a waist of time and money? It just shows that going from 3.73s to 4.30s the GCWR goes from 20K to 26K.
Old 03-14-2012, 09:40 PM
I pulled 29k 1600 miles over a few passes and the worst I saw was 180 after getting cut off, loosing momentum and getting stuck in 1st with the converter unlocked for a mile.
Old 03-19-2012, 10:21 AM
I got a 31 row 6.0 trans cooler. Does anyone have a write up on the install with pictures? I am also looking around for the correct lines, hoses and connections required for the install. Thx!!
Old 04-18-2012, 09:22 AM
Got the Hauler! I put the 31 row 6.0 tranny cooler in and everything seems to work great!!!
