Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > What a Powerstroke is for, Towing and Hauling
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 09-12-2007, 10:25 AM
Marv Marv is offline
New PSD owner with some towing/hauling questions
What's up everybody...new member here. Just bought an 05 F-250 SD PSD (CC, 4WD, Lariat, FX4, 38k miles) about two months ago and had a couple questions regarding towing/hauling capacities. I've read tons of info on the web about this, but usually end up confused..haha.
Anyway, I will be needing to haul hay for an uncle this year and it looks like a gooseneck trailer will be in order. Will probably be picking up my B&W turnover ball system either today or tomorrow (30K # system), so that'll be taken care of.
My question is, what exactly is the towing capacity of the truck in this configuration with a gooseneck?
17,000 lbs?
I'll probably be using a 25-30 ft dual axle gooseneck with ~12-14, 600-800 lb rolls on it.
Is being overweight gonna be a problem?
Truck has the original Contitrac tires on it (18") - any idea on what pressure to run?
I'm sure I'll think of more, but if anyone could give me a hand, I'd really appreciate it.
Thanks!
Marv
Old 09-12-2007, 10:45 AM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
First - Welcome to the .org!!! Glad you chose to join!
Look on the sticker inside your door for the rear axle (3200 ish???)rating and tire pressures..
as far as towing capacity - I know my 01 F250 is 15K for a 5th wheel/gooseneck style trailer... hope that helps.
Old 09-12-2007, 10:59 AM
Blue, thanks for the warm welcome....it's good to be here - lot's of good info.
I'll check the sticker inside the door. Figured that would be a good place to start, but thought some of you folks would also have some comments.
Sounds like I should be able to handle the load....I'm sure it's good for 15k lbs on a gooseneck. But then again, I just wanted to check. Just didn't want to risk damage to anything.
Anyone else with advice, feel free to post up! I'm up for the advice!!!!
Thanks!
Old 09-12-2007, 11:09 AM
Banshee34 Banshee34 is offline
Welcome and congrats on the new rig!
Old 09-12-2007, 11:12 AM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
congrats on the new rig. and welcome to the Org
Old 09-12-2007, 12:48 PM
Thanks guys, I really appreciate it. So far so good...I've really enjoyed the truck.
Hard to leave it at home and drive anything else!!
Old 09-12-2007, 12:53 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Can't help you on your question, but I can you to Powerstroke.org
Old 09-13-2007, 12:22 PM
Thanks Vital, I appreciate it.
Got the B&W today...hope to install it tonight.
Anyone else have any tips/advice/comments?
Thanks.
Old 09-13-2007, 12:25 PM
Time to start modding!!!!
Old 09-13-2007, 12:26 PM
Actually even if you don't mod the truck get yourself some guages at the very least pulling that much weight
