Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > What a Powerstroke is for, Towing and Hauling
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 09-10-2007, 07:29 PM
rcoker6493 rcoker6493 is offline
Cool Tow/Haul -02 7.3 PSD -- Should I use overdrive
I have been told by several that when hauling heavy loads 12-15K that I should run the 4R100 out of overdrive in third gear.. I know that when I 'am hauling it does not always kick down easy when running in stock or especially when running the TS-Chip in 50 / 75 over stock.. Any body out there towing with a 7.3 that can give some advise on whether the over dirve should be OFF or not? I run the mountains all the time hauling horses and if running means over riding over drive while hauling then so be it. I just want to make sure that I 'am doing the right thing nd do not want to do anything to damage the truck unnecessarily.
Old 09-10-2007, 10:09 PM
blk99 blk99 is offline
I NEVER tow in O/D unless I am on the flats doing 70-75mph! I dont know about you but I have 3.73 gears and I cant be in OD on hills cause my temps sky rocket(at least 1200-1250) and the "Coal Really Roles"! But when I pull it out of OD the temps usually drop to 800-900. Anyway I will not hurt the truck to run it with a load out of OD. The only I time I found that being out of OD hurt is when I tried to speed(75+) up a hill with 16,000# and I was pushing the motors redline and it over heated but other than that time it has NEVER had a problem.
sorry for the long post.
~Jim
Old 09-11-2007, 08:33 PM
lilredpowerstroke lilredpowerstroke is offline
It all depends on weather or not the tranny is hunting or not. Since you have a chip Im gonna assume you have gauges in your truck. I live in Florida so the biggest hill I have to pull on is an overpass but if you watch your gauges and drive according to them then you should be safe.
Old 09-11-2007, 09:16 PM
colo86GN colo86GN is offline
~Jim
I have the sam eissue and pull over mountains all the time. If i leave mine in overdrive and try to ease into it my EGT temps start rising and it doesn't go anywhere to fast. I always kick mine out of overdrive, my EGT's drop to a lower, safer temp, and it seems like it is easier on the truck to make it up the hills. Basically, the same as the post above says. I don't see anything wrong with putting it in 3rd gear, especially when the truck temps are reading better.
Old 09-11-2007, 09:55 PM
jfines@cox.net jfines@cox.net is offline
I agree with all of the above. I am having my trans rebuilt right now. And I have been able to watch all the parts as they come out. The O/D looked good, you could actually still read the print on the clutches. But I had burned out the 2nd and 3rd clutches, which at 126,00o on the clock, I think that's good.
Well any way, the discussion came up about towing in O/D he said that it's not a good idea if your tranny keeps hunting for the right gear. Being that my rig with the 5th wheel is about 22,000 pounds, the hunting is often.
Of course I am getting all the upgrades for the trans, and he said I can tow in over drive with what I am getting. BUT, he also said that if you do, always downshift (turn off O/D) before you start to go down the other side.
So, I still think I am going to do it the old way. Since there is no reason to go 75MPH with the 5er in the hills, down shifting wont be a problem.
Also, I have the late E4OD, which I told was made in 98. Which from everything that I have seen at his shop, it is almost like the 4R100. And my rear axel is 4.10, that helps.
Old 09-11-2007, 10:17 PM
jmcclellan jmcclellan is offline
I am pretty new to this diesel thing but I notice the same that everyone has mentioned above. But with a load of 15k there is no way I would tow in overdrive. If you do really keep an eye on the egt's they skyrocket until you feed that engine more air.
Old 09-13-2007, 02:34 AM
Appreciate the feedback... Just curious about the trans temp running out of O/D.. Those of you pulling in the hills. What do you get for trans temps when pulling heavy weight out of O/D?
Old 09-13-2007, 07:15 AM
Well actually, towing in O/D can raise you temps. Basically, what I have experianced, when the trans starts to search for gears, like shifting between drive and O/D, that creates heat. Plus, O/D isn't made for that type of stress unless you have had it rebuilt.
As for temps, with the stock trans,in good health, I would see about 200-210 going up hill.
A good piece of insurance, is to get a larger trans cooler.
Also, when I tow in the mountains, I take over and shift for the truck to prevent it from searching. Most of my uphill is done in second.
Also, with sifting down, your exhaust temps stay lower, i know it sounds funny, but it's true.
Plus, my 5th wheel weighs in at about 14,000 lbs.
Old 09-17-2007, 07:45 PM
On a hot day(90-100deg.) my trans temps are 200-210 on most days the temps average 165-185. That is with a small aux. trans cooler that has a fan but the fan is never used unless in town. Those temps are usually while climbing with a 16,000# sail on behind(5er)!
Old 11-19-2009, 04:37 AM
Redye Redye is offline
Would towing up steep grades in four wheel low help to keep transmission temps low?
I have done a liquid (engine) radiator bypass, two 15" X 15" aux coolers in parallel configuration, plus 3.5 quart PML trans. pan, hauling 8000# on level interstate at 60mph, 85 degree day, I run at about 165 deg. As soon as I hit a steep grade, say 10-15% mt tranny goes to 220 deg.
