Hitch and air bags ????s - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 3 Old 12-21-2011, 09:43 PM Thread Starter
When I bought my truck it already had airlift load lift 5000 bags on it. I am looking to install a gooseneck hitch but can't seem to find a conclusive answer on which ones will work with what set up. My bags are mounted to the outside of the frame rails vs between frame and axle. I really want to install a B&W turnover ball and want to make sure this will work before I drop the coin on it. Looking for thoughts from guys that have this set up. And if the B&W won't work which one will?
2004 F250 6.0L CC SWB 4x4 (name's Eleanor)
Straight Piped, Coolant Filter, EGR Delete, Blue Spring'd, Amsoil'd, ELC'd, Rev-x'd, S&B Intake
JumpinJack is offline
post #2 of 3 Old 12-21-2011, 10:04 PM
44magnum's Avatar
Air lift has 4 diffrent air bag systems for your 04 4x4 truck, part #57215 wont fit with a hitch and part #57390, #57291 (B&W 1105 and 1199R with slight modification to brackets only) & #57298 (reese 5th wheel) will fit with a hitch. All you have to do now is figure out which it you have! But the #57390 says its a "underframe mounting" So you probably dopnt have that one. Call the company and see if they can help you id your setup. Good luck! Interactive Application Guide | Air Lift Company
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #3 of 3 Old 12-22-2011, 01:05 PM Thread Starter
Alright so I found out that I have the 57215 kit. However one the previous owners did have a fifth wheel installed. He used the universal rail kit to get around the airbag set up. I could go this route and get the best of both worlds as far as gooseneck/5th wheel combo but don't know how well it hold up with one of the gooseneck plates attached, this would also save me a large chunk of change. I don't have any future plans for a 5th wheel right now but never know with a wife that likes to "camp" in luxury (just give me a sleeping bag and fire and I'm good).
So is there anyone out there running one of the gooseneck adapters mounted in the 5th wheel rails and if so how do you like the set up?
