What to unplug when welding on frame - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 12-16-2011, 03:55 PM
I'm installing a goose neck hitch on my 08 6.4 tomorrow. I'm going to weld it in. I need to know what i need to unplug electrically on the truck. i know i need to disconnect the batteries, is there anything else i need to unplug?
Thanks in advance for the help
Old 12-16-2011, 04:21 PM
bump to the top.
its amazing how fast this gets pushed off the front page.
Old 12-16-2011, 04:25 PM
Why weld it? Just makes it permanent, and you may wanna put rails in one day and it'll be in the way.
If you wanna weld, then unplug the batteries, and that should be fine.
Old 12-16-2011, 04:32 PM
its cheaper. thats really the only reason. i know ppl that have theirs welded in and they say they dont really get in the way to much. if it does get in the way ill go ahead and drop the coin on a b&w.
Old 12-17-2011, 08:17 AM
whether you weld or not is up to you, as far as disconnecting.... i have welded on many superduties both diesel and gas, and used to always unhook the battery religiously to protect the computer etc.... after years of doing it, i have welded on trucks without disconnecting anything and never had an issue. If at all able, you need to disconnect the batteries to protect.
Old 12-18-2011, 06:33 AM
Thanks for the info. I disconnected the batteries and made sure I had a really good ground and everything went fine. I'll post pics later.
Old 12-23-2011, 02:33 PM
Why weld? 4 grade 8 1/2 in bolts and a drill do just as good of work and you can take it out...
Old 12-27-2011, 12:09 PM
I use my 6.0 every day for welding and weld right off the tailgate never disconecting my batt.s
Old 12-30-2011, 02:30 PM
Just run the ground clamp for your welder as close to where you are welding and preferably connected to the same piece of steel (not through something bolted to the part you are welding) and you should be fine. I do usually disconnect the ground clamps on my batteries though. No reason to risk damaging something expensive.
