Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > What a Powerstroke is for, Towing and Hauling
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 08-30-2007, 12:05 PM
msmith5280 msmith5280 is offline
Turbo working right?
Howdy! I finally was able to use my truck to tow a 5th wheel 36' travel trailer (about 11k lbs.). I was driving about 70 mph w/ 2400 rpms and it sounded like the turbo was cycling on and off.... is this normal? The gauge was not showing any noticeable loss of boost.
Old 08-30-2007, 12:14 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Probobly your fan clutch cycling with the extra load.
Old 08-31-2007, 04:24 AM
thanks Vitalidle!...ummm is the fan cycling a normal thing or is it on the way out?
Old 08-31-2007, 04:54 AM
Actually yes your fan will change speeds depending on the temp of the air blowing over the spring. The warmer the air the spring will unwind and cause the fan clutch to engage and speed up the cooling fan. Thats it in a nutshell its probobly alot more complicated then that!
Old 08-31-2007, 05:01 AM
dustindiesel dustindiesel is offline
could be the a/c compressor as well..that would be my guess
Old 09-01-2007, 04:20 PM
Hazcat@charter.net Hazcat@charter.net is offline
The cooling fan has a turbo like sound.
Old 09-01-2007, 04:27 PM
Ditty Ditty is offline
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Could be surge. Is it doing it under load, while accelerating? Like a very fast "WHOOSH WHOOSH WHOOSH!!!"???
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
