trailer plug problem - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 10-31-2011, 06:41 AM
Ok guys i need your help. I went to hook up the trailer yesterday and when i plug in the trailer it was saying trailer disconnected and then after it was saying wiring fault on trailer. I know its not the trailer because it has worked fine on my truck and it worked fine on my stepdads dodge . Also it did the same on two other trailers. Any ideas what it could be? A fuse? Any help is appreciated.
Old 10-31-2011, 06:46 AM
You'll have to check your Owner's manual - I believe there are several fuses and perhaps some relays that are specific to the trailer connection.
Old 10-31-2011, 06:49 AM
Yea i was looking at the manual. I am just not sure which one it might be listed as. Is there any way to check if a relay is bad? Does it sound like a fuse problem?
Old 10-31-2011, 01:04 PM
well i got a prong to test the connectors. THe + connection lights up and the running lights light up. When i test with the left and right blinker and the brakes there is no power. Any ideas?
Old 10-31-2011, 07:25 PM
blown fuses... my plug on my truck is all beat up and on occasion water gets in there and blows fuses... same thing, some things work, some things dont... Ford has separate fuses for trailer towing which is nice...
Old 11-01-2011, 01:17 AM
It could be blown fuses, most of them are in the fuse panel under the hood. (assuming its the '08 in your sig) If your fuses aren't blown take the connector apart it could be corroded . The plug on my '06 had green corrosion on the prongs inside the connector. I cleaned them up the best i could and put die electric grease all over the connectors. Haven't had a problem since.
Old 11-01-2011, 09:52 AM
I have had the same problem with my 2010....I just unplugged the cord and plugged it back in and that stopped the problem....I need to use some electrical grease.
Old 11-08-2011, 08:25 PM
I just noticed today that mine was saying trailer disconnected, went back to find out that the plug to the plug was loose.....the truck side, female, part of the plug is also plugged in to the harness behind it, it all looks like one piece but its not, may check this
Old 11-23-2011, 12:14 AM
yes there is a plug between the truck harness, and the actual receptacle on the rear bumper of the truck. therefore you have TWO places where you can have corrosion, that need to be checked and greased
