Am I missing something? - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 11 Old 10-25-2011, 03:53 AM Thread Starter
Over the summer, bought a 7.3 excursion, has all the toys Garret turbo, afe intake,ps chip, big exhaust and so on. What is bugging me is my 5.7 triton f150 pickup tows our family camper hands down better than this truck. I run into issues mostly on hilly sections, my egt gets up into the 11s so quickly I find myself crawling up hills, am I doing something wrong? Should I have something checked? For what it's worth the camper and everything is around 8500 lbs loaded (heavily). But it still struggles with it empty.
macsdaddy is offline
post #2 of 11 Old 11-14-2011, 05:52 PM
Country Mav's Avatar
Quoted: 2 Post(s)
How many miles are on the 7.3? What chip? Usually 7.3's pull pretty dang good! What's your gear ratio? Honestly, I've had 2 trucks with the 5.4 triton and it's a gooooood motor IMO... But the 7.3 should be competing! What kind of air filter? Good and clean?
2005 F-250 Lariat FX4 CC SB
Sinister EGR Delete
Diamond Eye 5" Turbo Back Straight
OEM Gaskets and ARP Studs...
SCT X3 (Quick-Tricks tuning)
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
Rebuilt FICM with Atlas 40
2006 F-350 XL RC/Flat Bed
EGR Delete
SCT SF3 (stays on tow agg)
FARM TRUCK
Diesel spark plugs are the bestest spark plugs....
Country Mav is offline
post #3 of 11 Old 11-14-2011, 05:54 PM
jesilvas's Avatar
Quoted: 3 Post(s)
What kind of boost are you running also?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 11 Old 11-14-2011, 07:12 PM
atvrider93's Avatar
Quoted: 8 Post(s)
garrett turbo is stock.....
did you mean to say TS chip? what setting are you towing on? what EGTs are you seeing unloaded?
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #5 of 11 Old 11-15-2011, 05:38 AM Thread Starter
Yes sorry, TS 6 position chip, the Garret is the ball bearing turbo unit, I have an AFE intake and it was cleaned and oiled 2k miles ago. The truck has about 118k on it now. Bost runs pretty low, I am lucky to get it to 15 and it is mostly in the 2-5 range. I am thinking I have an issue with my up pipes, I have all the signs of the leaking under the hood. I am looking at a replacment set now, but I just need to convince myself to part with the money.
post #6 of 11 Old 11-15-2011, 09:40 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Your up pipes are the exhaust pipes running from the manifolds to the back of the turbo. If they are leaking you'd see soot on the firewall.
What do you mean 'signs of the leaking under the hood?'
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 11 Old 11-15-2011, 09:56 AM
Mikey's250's Avatar
I think you have a boost leak. 15 psi is pretty low for your max with a chip. I see 15 just leaving red lights hard unloaded.
Michael- Georgia Powerstroke Diesel Association
2002 F-250 ECSB 4X4 Lariat
Mikey's250 is offline
post #8 of 11 Old 11-15-2011, 10:39 AM Thread Starter
Actually have soot at the connection joints and a strong diesel exhaust odor when I am not moving..how do I chase down a boost leak?
post #9 of 11 Old 11-15-2011, 11:58 AM
Mikey's250's Avatar
Well you can remove, clean and check the rubber intercooler boots but if you have noticable soot at the up pipe connection then that is most likely your problem. I just replaced the donut gaskets instead of buying the $400 IH bellowed up pipes.
post #10 of 11 Old 11-15-2011, 02:35 PM Thread Starter
I considered doing only the gaskets but there is something attractive about not having to do the repair again with the bellowed pipes.. How long did it take you?
