Towing with 37's - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 08-15-2011, 11:04 AM
Send a message via AIM to tristanlee85 Send a message via MSN to tristanlee85 Send a message via Yahoo to tristanlee85
Towing with 37's
I recently upgraded from 32's to 37's and have noticed it requires a lot more for me to get rolling from a stop. I have the 6-speed and even without towing anything, I always find myself starting off in low instead of 1st now as it seems to bog down a good bit unless I slip the clutch to get rolling.
On top of that, towing my 17.5' bass boat in 4th seems to be about the best gear for me. I don't find myself wanting to go in to 5th until 65mph or so as it seems like there is just too much of a load.
Is this where I'm told to deal with it or get a different rear end? Thanks.
Old 08-15-2011, 11:56 AM
wow.. i'd throw some gears under there for sure.. 37's? im gonna take an educated guess and say 4.30's are about right for ya. im sure someonee else will chime in.
Old 08-15-2011, 12:17 PM
Feedback Score: 5 reviews
Gears or HP is whats needed, best both....4.10 or 4.3's with a chip or stage 1's will get the job done.
Old 08-15-2011, 12:31 PM
I'll check the sticker tonight to see what I currently have (guessing 3.73's??). Either way, being 4x4 the front and rear would need replaced correct? It's probably cheaper to just lower the truck and get smaller tires. I didn't realize it would be this bad or I would have limited myself to 35's.
Old 08-15-2011, 12:33 PM
I don't have a chip, but I do have the Flashpaq that is set of "performance" which I believe is their highest HP setting.
Old 08-15-2011, 05:13 PM
3.73 on 31.5 (stock) equals nearly exactly the same ratio as 37s with 4.56. 4.30s would be a good mix of cruising and towing. Want stock ratio, need 4.56
Old 08-21-2011, 08:28 AM
I have 4.56 and 37s. It is a perfect combination. 4.10 and 4.30 just aren't worth the money as there won't be much of a difference. I tow a lot so it works perfect for me as I can tow in overdrive most of the time.
