Gooseneck hitch question - Ford Powerstroke Diesel Forum
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
post #1 of 46 Old 08-12-2011, 07:34 PM Thread Starter
Ipkyss's Avatar
Just bought a new trailer and b&w turnover ball. Trailer is a 36x8.5 enclosed goose with a 2ft V nose. The hitch on the trailer is right on the front edge on the trailer. I thought with the V nose I would be good to go with my short bed, but its gets close quick. I just picked up the B&W ball that moves it back 4". Have not checked to see how much of a difference it makes yet.
I feel like the hitch on the truck is too far forward. I believe it is about 6" forward of the axle. Has anyone modified the B&W hitch to be slide back some? It sits right on the flat part of the frame and there is room to move it back.
I remember seeing a extension for the trailer before, but I am not sure if they put too much stress on the trailer? Its an all aluminum trailer, but will only be around 14k fully loaded.
2008 F-250 6.4 Auto, CC,SB,FX4, 2" lift, 285/65/20, Spartan tuning, Elite studs, Elite egr delete/wastegate, Elite push rods, Spearco Intercooler, cold side pipe,CFM, 4"down pipe,Custom 5" DP back exhuast 543HP/1231 ft-lbs
Everything from Sean at Street diesel performance
Ipkyss is offline
post #2 of 46 Old 08-13-2011, 05:01 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
A turn over ball 6" in front of the axle is exactly where it needs to be. They do that so that when the trailer is on some of the weight is kept over your steers. I have used those adapters that move the hitch back and at only four inches you will still be fine for weight. You definitely do not want the ball anywhere behind your rear axle, that is just asking for trouble. In your pic it looks like you have an over the ril tool box. My best advice is to lose the tool box and get and in bed one that stays below the rails or go buy a long bed truck.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 46 Old 08-13-2011, 08:19 PM Thread Starter
Ipkyss's Avatar
Differently no option of getting a long bed. Not after just getting the motor in this one built. Tool box is only a few inches above the rails so it should not be much of an issue. Going to hook it up with the 4" back ball tomorrow and see how much it helps. It does tow really nice as is. Makes me wonder why I ever went back to tag trailers. 90% of my towing will be from home, to the highway, to a large parking area so it should not be a huge deal.
Ipkyss is offline
post #4 of 46 Old 08-13-2011, 09:00 PM
WD40's Avatar
Quoted: 30 Post(s)
b&w turnover ball
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #5 of 46 Old 08-14-2011, 12:08 PM Thread Starter
Ipkyss's Avatar
Is that a question or an answer?
Ipkyss is offline
post #6 of 46 Old 08-15-2011, 03:37 PM Thread Starter
Ipkyss's Avatar
well as odd as it seems. The 4" back hitch made a huge difference. I would say about an extra 15-20* of turn before it gets really close. I can turn to about 80* before I am a few inches from the cab corner. Not perfect, But good enough to keep me happy.
Ipkyss is offline
post #7 of 46 Old 08-15-2011, 04:56 PM
Quoted: 6 Post(s)
Well that is good and I am glad that it is working for you.
post #8 of 46 Old 08-16-2011, 08:29 PM Thread Starter
Ipkyss's Avatar
This is with the 4" back ball. It seems like there is tons of room, not nearly as much as I thought when I first picked it up.
http://i601.photobucket.com/albums/t...0/IMAG1227.jpg
Ipkyss is offline
post #9 of 46 Old 08-25-2011, 04:21 PM
44magnum's Avatar
Quoted: 2 Post(s)
I had the same issue with the gooseneck I bought a couple weeks ago, a 38'x8.5' with no V-nose won't turn more than about 45 degrees before it would touch the cab. Luckly the guy I bought the trailer from had this custom hitch, it gives me about 16" more so now it lets me turn about 75/80 degrees before the trailer would touch the cab.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #10 of 46 Old 08-25-2011, 04:24 PM
44magnum's Avatar
Quoted: 2 Post(s)
Sorry for the big pics, you wouldnt think a cel phone pic would end up being so f-ing big.
44magnum is offline
