| What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers |
Brake controllers
There's a ton of info out here about GxWR and suspension and air bags and mods to help the truck move a load, but what about stopping them? Most of the RVs, goosenecks, and longer bumper hitch trailers are going to be using electronic brakes, I'm guessing, so what controller are y'all using? Does it really matter? Or do you just point the rig uphill or towards a line of Priuses when you want to stop?
Had an simple old one in the 96 when I bought it, switched it out to a Tenkosha P3 and it changed my life. Electric brakes on both the trailers I pull. Soooo much smoother, and the boost settings are great.
Good brake controllers definitely make a differeence, been looking to upgrade to a P2 or P3 myself. Here's a good site for ya. Brake Controller
I just upgraded from a tekonsha envoy to a p3 and its very nice. Nothing wrong with the envoy, it just doesn't play very well with the electric over hydraulic brakes on one of my new trailers. Its actually for sale in the interior section..just fyi
My truck has the factory installed trailer brake, it works better than the tekonsha i used to have & it does not stick out where my knee will hit it. Ford got it right with this set-up.
I got the P3 in mine, love it. I don't have much expierence with other models since this is the first I have owned, but i read lots of positive things about it so I went ahead and got it. I don't regret the purchase one bit, and the boost setting are nice. I like that I can turn up the boost on the brakes when my dads 4500lb car is locked inside my trailer, makes stopping very smooth.
Wow... lots of love for a Tekonsha. I'll have to look at those. And DDBCK, that apparently wasn't an option in 2004.
Great info
Found this thread searching for controllers, but I have a REALLY dumb newb question...figured here is as good a place to ask it as any. I towed a 2,300 pound car hauler saturday with electric brakes about 80 miles to pick up a CJ-5 project for a buddy. We loaded the CJ on the trailer. Now my estimates based on the CJ's I've owned in the past put this one (factory axles, 33" tires" no lift, nothign odd) at ABOUT 3,000 pounds. Couple that with the trailer, and we're talking a load of about +/-5,500 pounds. But when loaded up the truck acted like there was not a THING behind it. Now my truck is a 2005 F350 DRW with the pocket where the Aux/controller option would normally go, and I don't have an visible signs of a controller ever being mounted in the cab. Bought the truck from a dealer who couldn't verify if it had one installed, and it's got a turnover gooseneck hitch in the bed as well as the rear towing hitch and 7 pin plug. My question is: Does the 2005-newer F350's come with an integrated controller? That maybe isn't adjustible? Is there a common sense way of finding out if I have a controller that just can't be seen, that I'm maybe missing? Can you check voltage on the 7-pin and see if there is electrical going to what would be the trailer brakes? Again...sorry for the ignorance. But I'm TRYING to educate myself here. |
Hi Troy, If it ever had the controller, it would have a different brake booster on it and the PCM would have programming to allow it to communicate with the brake booster and the brake controller. I'm sure that there is a visible way to tell the difference on the brake booster, but the dealer would have to be able to look at the PCM to verify the programming. My guess would be that it never had the brake controller.
PS. I have looked at upgrading to the integrated brake controller and the cost of components and hassle has kept me from pursuing it any further. Finally, I am running the Prodigy (P1) in my wife's Dodge and just upgraded to the P3 from the P1 in my truck and it is the only way to go for an aftermarket brake controller. |
Thanks so much!
I'm looking at the P3 after this thread and many other controller threads. Another kinda dumb question (I think) is: If I buy a P3, is it simply plug and play? And bam...now I have trailer brake control? Thanks |
