Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > What a Powerstroke is for, Towing and Hauling
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
  #11 (permalink)
Old 05-18-2007, 12:10 AM
worx worx is offline
Send a message via Yahoo to worx
I went with the spot just under that little hook, on the passenger side of the center of the dash- the trash bag hook. I could still reach it but would not normally get kicked... I would ahve mounted it closer- like under the little opening but I already had the vhf and cb radios mounted there- stacked...
I might move it over next to the radios if I get a chance, but have alot of other projects to do before that... make it easier to grab now that the tablet got mounted...
  #12 (permalink)
Old 05-27-2007, 01:46 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
Here's mine - looks noticable in the pics - but with tinted window and being under the dash, its outta the way and still reachable in an emergency braking situation, and looks clean... I'll try to take one from the side soon to show that its back "under" the dash - not sticking out like it looks in the pic...
  #13 (permalink)
Old 05-29-2007, 05:18 PM
Lord Tauk Lord Tauk is offline
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
That looks pretty good. My only problem is if I ever have anyone sitting in the middle, they might kick it? This would rarely ever happen but you never know.
I'm still leaning on the cubby hole right now, I even thought about taking out the cup holder next to it and mounting it in there.
  #14 (permalink)
Old 05-29-2007, 05:23 PM
Tournaments Won: 1
Well, the my Prodigy came with two brackets -- the plastic on that I used there that you can remove the controller and then a metal one that can be under/over the controller and is scewed to the controller. I just liked the idea of being able to remove it if I ever drop it off for service or must leave my truck unattended...I'll see what I can do about a pic on Friday when I get off work!
  #15 (permalink)
Old 05-29-2007, 05:30 PM
That's cool, I don't have the controller yet so I don't have any real solutions on what I'm going to do so I'm just kinda arm chair guesstimating right now.
  #16 (permalink)
Old 05-29-2007, 05:34 PM
Tournaments Won: 1
I'll show some pics of the brackets that it has and everything - was gonna do it friday - but i'm just gonna go run and do it right now..
comming right up!!
  #17 (permalink)
Old 05-29-2007, 05:54 PM
OLDTOM OLDTOM is offline
I mounted my controller to the surface of the dash below the cubby. The controller has an adjustment for level. It is held to the dash with button type velcro. Only once did it fall down but the temp was -5. After the cab warmed up I stuck it back up and have no problem since. No holes to drill and no sign of being there at resale time.
  #18 (permalink)
Old 05-29-2007, 06:30 PM
Tournaments Won: 1
Here are some pics!
INSIDE THE CUBBY - can't reach the emergency lever...
Here it would be sticking out...so not sure what would work...
Hope these help.
  #19 (permalink)
Old 05-29-2007, 06:45 PM
Logan Logan is offline
The Fat Mod
Thats where mine is too. Works just fine there. Never had an issue with it. I do have the center console, so noone is going to be sitting in the middle.
  #20 (permalink)
Old 05-31-2007, 06:07 PM
That's right, the Emergency lever is on the rear of the controller isn't it?
Thanks for those awesome pics. Kinda rethinking it now since the emergency lever is an issue now, always something..
Anyway, I'll probably end up mounting it below the cubby hole like how you and everyone else got it.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
