Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > What a Powerstroke is for, Towing and Hauling
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
  #21 (permalink)
Old 07-11-2007, 04:46 AM
quick26 quick26 is offline
thanks for the reply country2. what size trailer are you hauling?
  #22 (permalink)
Old 07-11-2007, 09:58 AM
country2 country2 is offline
I have the B&W Turn over ball Turnover Ball Gooseneck Hitch In my truck and the colibert adapter on the camper. I pull a 32' fithwheel that is about 11000 lbs. I like the set up because when I need a smooth bed it is easy to turn the ball over and when I am towing I have a lot of bed room. The people at colibert will talk to you if you have questions. They are both clean easy installs that look good.
  #23 (permalink)
Old 07-11-2007, 10:26 AM
owtcast owtcast is offline
I'm running the Reese/Drawtite signature series. With both hitches it covers all bases. It can be unlocked and removed in seconds with no tools and leaves nothing in the bed to obstruct using the bed. It also is rated at 30,000lbs. That's almost TWICE the weight rating that most other hitches are. Here's a thread from the past with some pics of the hitch in and removed. Scroll down to bottom.
Fifth Wheel adaptors for my King Ranch 350 available in the States?
I currently don't have the 5th wheel hitch but plan on getting it too. It fits in the same mounting spots.
  #24 (permalink)
Old 07-11-2007, 11:36 AM
the truck came with the reese set up where you have the plate and the 2 ubolts that are spring loaded. the remove a ball one
Drawtite & Reese Fifth Wheel Hitches
