Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > What a Powerstroke is for, Towing and Hauling
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 10-23-2009, 01:24 PM
DragRacer DragRacer is offline
Mileage while towing...
I have a 2000 DRW 2wd crew cab with a manual transmission. The truck is stone stock...
I recently towed a 24ft trailer loaded with my race car 1800 miles from Virginia to Memphis and back averaging 10 mpg. The truck tows great and pulled the long hills without any problems. I kept my cruise control set at 65mph and was turning ~2200 rpm.
I didn't buy my truck for fuel mileage but when I did my expenses for the trip the fuel costs were a little over 50% of the total.
Are there any cost effective mods that I can do that would improve the mileage while towing?
I really know very little about diesels so any suggestions you all can make would be greatly appreciated.
Thanks in advance...
Old 10-23-2009, 05:05 PM
JER-1 JER-1 is offline
Cool
Take the 4.10 gears out of the rear end and put in 3.73--or 3.55 that will lower your rpm's and will increase your fuel mileage.
I'm gonna change mine hopefully next year 4x4 I'll have to change the front and rears . loose a little towing power but not much for what your pulling probably under 8,000 lbs.
JER-1
Old 10-23-2009, 06:43 PM
JER-1...
I have thought about changing the gears. It may be something I consider down the road...
What about a chip or plug in tuner? Will those help with mileage?
Is it out the question to get 15 mpg towing such a trailer?
Old 10-23-2009, 07:12 PM
tubular031 tubular031 is offline
my truck seems to get 9-10 pulling my 12k 5th wheel, 11 pulling my little 12 foot enclosed trailer at about 7k and 12 pulling my little enclosed trailer empty at about 3k. I get 15 to 17 empty. mine is a 4wd auto with 3.73
my buddy has a 2002 2wd auto with 3.73 srw and gets 19 empty and 10 pulling his trailer at about 6k
Old 10-23-2009, 07:15 PM
Originally Posted by DragRacer View Post
JER-1...
All I have learned is a tuner adds power and keeps my mpgs the same or a tad lower. But ill take power and the same MPG any day
15 pulling is pretty much out of the question. Anyone that claims to get that much pulling 6k+ is probably listening to the over head computer and that lies! with my edge mine was saying I was getting 28 mpg! now with my chip it seems to be about 10% high vs what I caculate
Old 10-23-2009, 07:23 PM
jesilvas jesilvas is offline
I get about 11 pulling an 8k fifth wheel with just an intake and exhaust. Chip might that up a TAD. Like one or less. Best thing to do is put a really nice intake on it and let the exhaust flow out really fast.
Old 10-24-2009, 01:03 PM
Thank all for the responses...
I knew when I got the truck it was not for fuel mileage but rather the stability towing and not having to worry about having enough power to pull hills, etc... It definately does a fantastic job towing.
Maybe over the winter I will look at an exhaust and cold air intake.
Thanks again!!!
Old 10-27-2009, 06:54 AM
get a walker BTM. cut off the factory muffler and clamp it in place. I think mine was about $70 including the clamps. Most say weld but I dont have a welder. There is no need for a 4 inch exhaust. The restriction is the muffler not the pipes.
Then do the DIY intake for about $40. Your truck will like you more!
Old 10-27-2009, 07:55 AM
That's exactly what I did. Got if for about 65 and welded in for 60 by Meineke. They kinda freaked out when they say it but did a really good job. With those two things I went from about 14 mpg highway empty to 15 or 15.5. And from down around 8 towing that trailer to about 11. IT NEEDS AIR
Old 10-27-2009, 08:20 PM
tubular031...
Thanks for the advice!!! 10-4 on the Walker BTM!!!
Are there any links for the DIY intake procedure?
Thanks again!!!
