Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > What a Powerstroke is for, Towing and Hauling
What a Powerstroke is for, Towing and Hauling FAQs, How To's, What do you pull, 5ers
Old 03-07-2007, 07:31 PM
dieselbop dieselbop is offline
towing questions???
I am going to pick up a 25 foot trailer this weekend. I have never towed anything this long or heavy before. I wanted to know what I need to know when towing. Anything I shoud be aware of with a manual trans? How do I work and hook up my trailer brakes? Any input would be greatly appreciated!!
Old 03-07-2007, 07:44 PM
00powerstrokin 00powerstrokin is offline
Moderator
Send a message via Yahoo to 00powerstrokin
there should be a gray connector under the dash to the right of the gauge cluster to plug your trailer brake into
Logan Logan is offline
The Fat Mod
Hey dieselbop, I moved this thread for ya. With the 6 spd you should have no issues. In my old truck that was a 6 speed, sometimes I would start in low rather than 1st, but that is really the only thing with that. That way you did not have to slip the clutch too much. If you have guages, I would put your superchips in tow safe. If not, I would return it to stock. Your trailer brake may take a little adjusting to get it right, but I have always just gone off feel for that. Not sure it that is the right way, but that has worked for me. Pull you Mirrors all the way out, and look at for the idiots. Other than that, you should be good to go.
Old 03-07-2007, 07:45 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
You won't even know its back there I had a 22 ft trailer and towed it with my dads 02 before I bought my truck and it wasnt even working the truck at all. I don't know how to hook up trailer brakes, but Im sure somone will chime in who does.
The Fat Mod
Oh, I just saw that you have the commander. Just keep those EGTs under 1250 and your good.
Old 03-07-2007, 07:54 PM
The trailer brake is hooked up. I just need to know how they work?
Old 03-07-2007, 08:00 PM
As long as you have trailer brakes on your trailer it will send a signal when you hit the brake pedal to apply the brakes on the trailer to help you slow down and save your brakes on the truck.
Old 03-07-2007, 08:34 PM
Hayman Hayman is offline
There should be a adjustment nob on your trailer brake controller to increase or decrease the amount of brake pressure you put to the trailer, it depending on the weight of your load.
Old 03-08-2007, 01:00 PM
fourx4forfun fourx4forfun is offline
i found when towing my trailer to adjust it to where you could feel the trailer braking a little more than the truck, helped to keep everything in line for me, but do not have the trailer doing too much like the installer did mine, whoa, could barely touch the brake and the trailer was locking up.
Old 03-18-2007, 09:52 AM
randalst randalst is offline
Send a message via MSN to randalst
i just got a new trailer brake system with the auto leveling and such it very sweet but the book sais to cruise at 25 mph and increase brake pressure on the controller until the trailer locks up then back it of a bit and its set. havent tried it yet but thats what the book sias
