Just purchased 06 f350 drw, previous owner installed an aftermarket unit in it, would like to go back to oem setup an idea where I can buy a factory unit
They pop up here every now and then. Check the classified section here and if you do not find any joy, try ebay. I asked the question because if the truck did not come equipped from the factory with the controller, you would need to change the brake master cylinder for it to work...since it once had the factory one, and was removed, carry on.
Best of luck to you in your search.
Zmann, I don't understand your comment. The reason I believe it had the factory trailer brake controller, is because on the message center tbc is displayed.
Go to FordEtis home page, click on vehicle, then enter your VIN. That will give you the "as built" sheet of your truck. If it had the factory controller, it will be listed.
Thank you NYC, it was listed as original equipment on my truck
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
