Torqshift tranny flush in WV???
I've called 4 dealers in-- Buckhannon, Clarksburg, Elkins, and Weston. None of them can do a transmission flush on a 6.0L Powerstroke with a torqshift tranny (Mercon SP). Some places have a machine, but they have Mercon V instead of Mercon SP, and aren't willing to switch their fluid over to SP for a flush. Does anyone in WV actually do a proper tranny flush anywhere?
I wish you were closer to my area. I talked to my guy and he told me they would use whatever fluid I want and it would cost $179.00, of course I have to supply the fluid.
I just might have to come down there at this rate. It really blows my mind that no one around here can do an actual flush. You can't swing a dead cat around here without hitting a superduty... Heck, if I had the time it would probably be worth it to buy the dang machine and do them myself on the side. I ain't kiddin'-- this neck of the woods is very highly populated with SDs.If can't find anyone soon, I'm probably going to have to go on a vacation (to an area with a dealer that can do it) just to get it done... |
Hey man, another WV guy here! I live down Bluefield way and the Ford Dealer in Princeton (bout 3hrs from you) did mine for 177.xx tax and all! You may also check somewhere in Charleston!
Hey I am in Charleston, call Bert Wolfe Ford ask for big truck repair then ask for Jamie, or call Jerry at Cottman Transmission in Charleston.
Thanks guys, I'll check into those leads.
Just drop the pan add fluid and filters..what BTS recommends
Probably a dumb question but what is "BTS"? (I can't search a three letter item in the search function.)
try t and t in Phillipi. If Brett cant do it he may know someone that can. Brett is a top shelf guy and reasonable to boot. Hope this helps
Couple of options for you:
1) Don't worry about the filter in the pan. Its more like a screen than a filter. Drain out what you can (about 8 quarts), change the external filter, top off with SP, drive around, drain off another 8 quarts, and top off with SP again. 2) Find a transmission shop in your area that has SP or bring your own and use their machine. I did this a while back and they charged me $50. (I brought my own fluid). --Snake |
