07 Ford 6.0 350 runs rough - Ford Powerstroke Diesel Forum
Website Comments, Suggestions and Announcements Any Website Related comments go here.
post #1 of 10 Old 08-11-2013, 02:15 PM Thread Starter
My 07 Ford 6.0 350 runs rough when I first start up for the day. Lack of power and hesitates badly for about 2-3 miles until warm. I also notice when idling at a stop light it hesitates or runs a bit rough but not all the time. Getting less mpg than normal. Also had check engine go on for a day and went off and not back on since. 160,000 Miles.
I'm a new member and happy to hear from you.
Any help appreciated.
JimmyJ is offline
post #2 of 10 Old 08-11-2013, 02:19 PM
mastrkee's Avatar
Quoted: 4 Post(s)
Could be your egr valve needs cleaning. Or its probably stiction. A dose of revx should tell you of that's the case.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #3 of 10 Old 08-11-2013, 02:26 PM Thread Starter
Thanks Jeff but what is revx?
JimmyJ is offline
post #4 of 10 Old 08-11-2013, 02:37 PM
mastrkee's Avatar
Quoted: 4 Post(s)
It's an oil additive. I had the same issues that you describe and revx pretty much cleared them up. There's another additive that gets some good reviews bit I have no experience with it. It's called hotshot secrets. It won't fix the problem only injector repair will do that. It that is on fact your engines problem.
Jeff
mastrkee is offline
post #5 of 10 Old 08-11-2013, 02:43 PM Thread Starter
Okay, I just did oil change so I should add this to the oil and see if it works?
Can you recommend any injector solutions?
JimmyJ is offline
post #6 of 10 Old 08-11-2013, 02:46 PM
mastrkee's Avatar
Quoted: 4 Post(s)
Yes you can add it now. I suggest you talk to someone more knowledgeable about injectors.
Jeff
mastrkee is offline
post #7 of 10 Old 08-11-2013, 02:48 PM Thread Starter
Thanks Jeff
JimmyJ is offline
post #8 of 10 Old 08-12-2013, 08:02 PM Thread Starter
Found out today my truck has an electronic or electric egr valve. This changes the theory of oil treatment.
Any other ideas as to why running rough?
JimmyJ is offline
post #9 of 10 Old 08-13-2013, 03:42 AM
mastrkee's Avatar
Quoted: 4 Post(s)
What you found out changes nothing about the probability that your truck suffers from stiction. And that you should clean your egr valve. Good luck.
Jeff
mastrkee is offline
post #10 of 10 Old 08-13-2013, 04:45 AM Thread Starter
Okay, Thanks Jeff
JimmyJ is offline
