Egr cooler and exhaust questions
Ok so I'm new to the .org and new to diesels.
I just got an '04 F250 with 60k miles on it. I have changed all the fluids and filters on it. Everything about this truck is spotless and seems to have been well taken care off. None the less I want to change a few things. For the Egr cooler is my only choice one from Bullet Proof Diesel? Or is there something else us here in Cali can do? Also what do you all recommend for exhaust since we have to leave the CAT? Is there any advantage to changing out the exhaust? Thanks for any help and direction guys. |
Yep BulletProof EGR cooler and MBRP exhaust. MBRP make a nice 4 inch setup that keeps the stock cat. Replace the oil cooler when you do the egr cooler though.
A CAT delete help drop the exhaust gas temp.
On mine with just a cat delete, it dropped average of 150-175 cooler |
I thought I had to have mine to smog?
You do have to keep the cat for smog testing! If they do inspect the exhaust system for emssions and the cat is gone they will fail it. Some states dont have inspection. More and more states are implimenting emission testing and inspection, so if you dont have it now you might soon
You'll need the cat, if the truck came with it. Some folks leave a delete pipe in until inspection time, then swap the cat back in. CA does inspections and "smoke" tests every two years. If your truck has a VIN that ends odd, it will be in an odd year, if it ends even, an even year.
Mine ends with a '3' - So, this year, I had to have mine done. |
How do they do the emissions on diesels? Is it just a visual?
I have to smog mine next month,I have the stock cat thanks to a fellow stroker on here but I called the muffler shop and they are tellin me they will NOT install the cat unless its brand new or they get fined 2500.00 if the state finds out.How are you guys putting your cat back in if you have it deleted?I cant weld so any help would be appreciated. LA area here.
Can't you put it back in? Mine doesnt require any welding. Has a U bolt clamp thingy on one end and 2 studs on the other.
Just bought a 2006 F250 powerstroke. I want stacks any suggestions on size or brand?
