Cali SD smog Regs: What can I get away with modding - Ford Powerstroke Diesel Forum
Old 06-16-2012, 02:11 AM
I'm looking at getting an '02 CCLB to replace the '95. Right off the bat I wanna put a bigger intake and exhaust on, its always beena cheap way to free up power on these trucks. Am I gonna have to re-bolt the OEM system every year for smog, or will it pass with straight pipe? What about injector mods, etc? Thanks guys
Old 06-18-2012, 12:06 AM
Check to see if it has a cat. If it has a cat, you'll need to have the cat at inspections. As far as intakes, find one that has a CARB E.O. number. If it does, they won't fail you for it.
Old 10-10-2012, 12:57 AM
That is incorrect about the intakes, all intakes are legal. You are just less likely to encounter resistance with an EO number.
Read my article here:
Diesel Therapy: Guide to CA Smog
Old 11-12-2012, 12:42 PM
So by this the CCV mod is not legal and will need to be changed?
Old 11-13-2012, 10:00 PM
CCV
I routed my CCV back into the intake after the canister so that it would still be smog legal. Picked up the canister/filter at Tractor Supply. It's an inline filter used for spray rigs and it seems to work great. Pretty inexpensive too.
