FYI exhaust clamp - Ford Powerstroke Diesel Forum
Old 06-26-2009, 08:35 AM
FYI exhaust clamp
just in case you remove the clamp that holds the down pipe on the turbo and it strips out in the middle of the bolt while trying to remove it. Fords part number for it is: 6C3Z-5A231-AA if you call ford and try to order it like i did they might not order the correct one. they said under there list for clamps it does not show up only the one for the intake side that looks similar but is about a inch to little. good thing i had the old one with me to compare! oh and there around $35 plus tax
