Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Video/Movie Forum
  #71 (permalink)
Old 10-12-2007, 10:02 PM
97strokn&smokn 97strokn&smokn is offline
that my friend is a stock cam i no for a fact he was talkn about byn a cam from benn miller but he wasnt gonna do it till he tore it down over the winter. and its a p pump made custom from scheids that brad ingram built he had area diesel build him one and he stuck a plunger in his garage on the first start up. Knock on wood he hasnt had any problems with scheids pump.
  #72 (permalink)
Old 10-12-2007, 10:46 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Breaking balls since 1981
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
I don't know, that is awful, awful lopey for a stock cam......
  #73 (permalink)
Old 10-13-2007, 07:48 AM
BlkSmkAddict BlkSmkAddict is offline
correct me if i'm wrong but i believe that is just the timing.
  #74 (permalink)
Old 10-13-2007, 09:26 AM
Could be, but that's an awful lot
  #75 (permalink)
Old 10-13-2007, 10:39 AM
i know there was/is a discussion on this truck on TDG and the difference in timing between the HEUI and the p-pump make it rough to swap, which is why i doubt that is the stock cam.
BTW the truck was not over fueled at terre haute the turbo was trashed
  #76 (permalink)
Old 10-13-2007, 12:31 PM
ABOBB ABOBB is offline
Is it even worth it???
Originally Posted by 99Smokin73Stroker View Post
I don't think you can use a P-pump on a 7.3. The P7100 "P-Pump" off of Dodges only has enough to run 6 lines for 6 cylinders, so what are you going to do for the other cylinders?!
There is a V-8 version of the venerable Bosch P-series injection pump. I don't know for sure what pump Zimmer or Ben Miller are using, however.
A stock cam lopes like that?!
Depending on the cam timing, and how the injection pump is set up... a stock cam could lope like that.
  #77 (permalink)
Old 10-14-2007, 09:03 PM
But it isn't the "P-pump" that we are all so familiar with, which causes confusion.
  #78 (permalink)
Old 10-14-2007, 10:15 PM
the lopey sound is that they are putting so much fuel into the cylider it causes the engine to rev up when it is entered into the the cylinder and as it exits the the cylider de revs .
  #79 (permalink)
Old 10-15-2007, 02:52 AM
Miller uses an Mack E9 injection pump. At least thats what I've heard.
  #80 (permalink)
Old 10-15-2007, 03:04 AM
There are all different types of "P-pumps" four, six, eight, twelve cylinder pumps
Injection Pumps <- heres a bunch of pumps in here.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
