500HP Kit wanted for 97 7.3 - Ford Powerstroke Diesel Forum
Vendor Jungle Discuss / Promote Your Products , Give Support , Information , News , Prices , Group Buy Information Ect
Old 12-28-2008, 04:26 PM
PM me pricing on a complete kit with Inj, studs, turbo, fuel delivery system, programming. Looking for that combination that will get me 500hp on a daily driver. Twins turbos ok.
Old 12-28-2008, 04:42 PM
Ole White
Modded H2E Turbo $2500
Stage III 230cc Hybird Injectors $2400-2600
ITP Regulated Return $550
FASS or Airdog $650
SD *17 HPOP(High Pressure Oil Pump) used $200-300
In-Tank Mods $50-100
H-11 Head Studs $675-750
BTS Built Auto Tranny $5500-6000
SD Intercooler $100-150 and or Aftermarket $1300 will also need Banks or GTS IC pipes, intake spyder and boots $200-400
DP Tuner or Tony Wildman Chip $425-650 depending on # of tunes for DP up to 16 tunes
Comp 910 Valve Springs around $100
Water/ Meth Kit $500
Here's 500 hp DD on Fuel maybe a little over with meth
Old 12-28-2008, 04:48 PM
Hey thanks that is what I figured. Will that put me at 500hp? Sorry but I know nothing about building a ford. Sounds like it will and I was expecting to spend about that much. What should a typical install price be for everything but the tranny? I figure if you do it all at the same time it should save on labor since the heads are off.
Old 12-28-2008, 04:57 PM
Ole White
Not sure on all of it but I do know a local shop that has done work on my truck wanted $400-500 bucks to do Injectors, Glow Plugs, Turbo Pedistal, and Turbo install on my truck ended up doing it myself with the help of a couple buddies wasn't to bad
Old 12-28-2008, 05:00 PM
FASS or Airdog $650
wow man... great list
i can prob get you a price on everything but the Trans
-Raul
Old 12-28-2008, 05:01 PM
say no to rolling coal
Not absolutely necessary, but I would add an aftermarket single or dual HPOP setup to that list if it were me.
Old 12-28-2008, 05:05 PM
Real Men Love Jesus! <><
Stealth pump will assure you all the oil needed for your sticks, eventhough Hybrids take less oil than all other 230CC sticks
Old 12-28-2008, 05:17 PM
Ole White
Yeah thats the only reason I just put the 17 HPOP but hey if he's got another $2500-3000 depending on Stg I or II pump why not
Old 12-28-2008, 05:19 PM
Ole White
-Raul
Thanks Raul as you can tell I spend way to much time looking at 7.3 parts and on the ORG
sounds like there is NO budget on it.
