XDP Fuel Additive & Cetane Boost - Ford Powerstroke Diesel Forum
Vendor Jungle Discuss / Promote Your Products , Give Support , Information , News , Prices , Group Buy Information Ect
Old 11-11-2009, 03:43 PM
XDP knows diesel and has wanted to offer a fuel additive for some time. Finally, after a lengthy R&D process, we are proud to present our specially formulated concentrate for the best year round use in your diesel truck. Running XDP Diesel Power Plus in our own trucks through development gives you the confidence in knowing it's now ready for the masses and is the only diesel fuel additive for your investment.
Diesel fuels have changed but the problems associated with diesel fuel equipment have not. XDP Diesel Power Plus is a special formula which is compatible with all grades of diesel fuel and designed for year round use. XDP Diesel Power Plus contains cetane and lubricity additives to protect and enhance your engine's performance.
  • Totally disperses water
  • Cleans fuel injector system
  • Controls icing and freeze up
  • Prevents formation of algae and bacteria
  • Designed for BioDiesel and Ultra Low Sulfur Diesel fuel (ULSD)
  • Lubricates fuel system
  • Improves fuel economy
  • Decarbonizes nozzles and combustion camber
  • Reduces exhaust smoke
  • 5% Cetane increase
The diesel fuel we buy is always changing in both chemical content and quality. One constant is the propensity for diesel fuel to pick up water. Water in diesel fuel remains the number one fuel problem year round. Now that low sulfur and ultra low sulfur fuels account for the vast majority of diesel fuels used today, water is now a bigger problem than ever before. Water damages injectors, scores pintles, creates gum and varnish, interferes with fuel combustion and harbors microbes and fungi. Diesel Power Plus contains the most effective combination of ingredients to absorb water from fuel. The unique solution prevents damage, wear and premature fuel pump failure. Diesel Power Plus also helps improve combustion and mileage, stabilizes fuel, and prevents sludge. All of these benefits in a unique formulation which contains no harmful alcohols to attack your gaskets and seals. Our concentrated formula treats 500 gallons with only ounces.
The PLUS is a 5% Cetane Increase
What is Cetane?
Generally, diesel engines run well with a Cetane Number (CN) from 40 to 55. Fuels with a higher cetane number which have shorter ignition delays provide more time for the fuel combustion process to be completed. Hence, higher speed diesels operate more effectively with higher cetane number fuels. The national CN average is 45.
XDP Diesel Power Plus Fuel Additive
Old 11-11-2009, 03:45 PM
so this is like the RPB additive?
Old 11-11-2009, 03:50 PM
yup same stuff. we went right to the source
Old 11-11-2009, 05:33 PM
how much is this stuff going for. Id like to try a bottle
Old 11-11-2009, 05:38 PM
I'm also interested in trying some
Old 11-11-2009, 05:40 PM
I may give this a try instead of seafoam on my next filter change. It sounds good!
Old 11-12-2009, 05:02 AM
it's $6.95 a bottle. i've been running it in my benz for a few weeks now and did notice less smoke and a smoother idle. my boss runs it in his 08 LMM and he said he saw 1.34 mpg increase.
Old 11-12-2009, 05:21 AM
Will you be able to offer this stuff at a source other than on line,maybe Auto Zone,Pep boys ?
Old 11-12-2009, 06:19 AM
ha nope Xclusive to us here. it would be cool but i don't see it happening.
Old 11-17-2009, 02:51 PM
bumpin it up guys. special pricing for those looking for cases.
