| Truck Modifications A mods section to show off what you've done to the truck, or make write ups about what you've done. |
Ok i have wanted to do a 2" lift for a wile and now i have a bushing out on a front spring so i am thinking it is time! There are a couple of options and i was wondering what you folks thought. For the rear i will use factory 4" 350 blocks and i will need to get new U-bolts. Springs for the front is my dilemma.
I did some checking on having some new 2" front springs made and new u-bolts and this is what they told me, (Heavy duty three leaf front springs that add 1-1/2" to 2" are $224.27 each. U-bolts for the front would cost about $40.00 for a set of four, U-bolts for the rear would cost around $60.00 for a set of four.) This sounds like its on the spendy side! Or am i just getting old? All i want is springs that will give me 2" in the front not a rough ride and 1.5" or maybe 2". Am i asking for to much? There is always the add a leaf way but i think that will ride to rough. Or will factory 350 springs fit on my 250? Or forget about it and fix the bushing that is out? |
I edited this post as what I had posted before didn't pertain to a F250 with the TTB..sorry just spaced out.
If you lift a TTB you need to get a center drop bracket for the lift to correct the Camber change that will happen. I don't sell anything but shocks for a F250 with a TTB. I don't belive in spending anything on the TTB..if at all possible get a D60, RS kit with SD springs.. Cary Last edited by CT Performance, Inc.; 08-20-2010 at 09:30 AM. |
Do i realy need the track bar for 2"? It seems like there is plenty there to work. Or am i looking at it wrong? I could be
id say put a d60 under it or leave it as is..... I wouldnt lift a TTB
Well (deep subject) i am not sure what to do then. I think i will think about it for now. Thanks for the input guys!
