Ok I guess things were going too good for too long. I finially got my rebate check from
. I think they put some kind of powder on the check that reacted with the shift lever when I touched it! (by, the way, I see dead people) Have a 2002 F350 4x4 108K auto trans. I noticed a low whistle this morning while running empty and thought it was just the ice on my ladder rack. Later that morning I was backing my trailer (7K) up a hill and stoped mid-way to check my mirrors. Started to back up again and the truck shut off. I put it in N and started the truck and coasted back down the hill to make another run at it on a better line and nothing. P is the only position that worked. No movement in 4 wheel either. Took notice to a low whine while truck was ideling after that. Fluid top off and looks to be ok as well as the temp. Ford mechanic thought filter dropped (known problem in that trans) or valve went. Reccomends new trans because of warrenty. Dealer wants $3900. Any other time I'd grit my teeth and get it done but work is slow and I'm pinching pennies..............any thoughts? I'm thinking its the TC with the engine stall and from what I've been reading here. Any info or sympathy would be welcomed!Thanks |
I would def. buy a prebuilt tranny, one of the guys will chime in, i think a john wood is one of them? maybe idk, i got a manual, but these guys will tell you to get an aftermarket tranny.
Where you located I know a guy who could get you a deal on a built trans his in ohio
Harrisburg area.........................love the boots...........go OK!
by the way.............I bought this truck in TX
if you want pm me your number and I will have zack call you from fast track enterprise and he can quote you a trans he is in cleveland ohio.
