91 F-350 4X4 IDI AUTO TRANNY TROUBLES? - Ford Powerstroke Diesel Forum
Old 12-29-2008, 04:54 AM
Just bought a 1991 F-350 cew cab single wheel 4x4 truck, with 138-k miles. 7.3L IDI, automatic overdrive and BONE STOCK other than oversized tires and wheels. (315x75R16's)
Tranny seems slow going into reverse (like 3 to 5 seconds) and sometimes slow going into drive, while driving it seems a little funny to me going into OD sometime as well. Fluid looks good and has no smell to it. Is this something common with the early models or do I need to have it checked out???
Old 12-29-2008, 04:53 PM
remove connector behind sheild on trans and check for corrosion, common problem also are you having tach problems? if so replace tach sensor
Old 12-29-2008, 06:50 PM
91 tranny troubles???
Behind the shield on the trans???? Are you talking about the dust cover on the bottom half?
Does not seem to be having any tach problems at all. I will double check on the way to work in the morning. Thanks
