Where do the oil lines go!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-23-2014, 07:08 PM Thread Starter
Larry1997's Avatar
The lines coming out of my transmission sprang a leak and needed replacing. I assumed that they both went to the oil cooler behind the grill, but they don't. One goes to the oil cooler and the other goes to the bottom of the radiator. Now I don't know which one goes where…
Can anyone tell me which one goes where? They are rigged lines on the passenger side of the tranny. There is a long one that comes from the back of the transmission, and a short one that is closer to the front. They both come out behind the motor fan.
Any info is appreciated.
My baby is a 1997 F250 7.3 Powerstroke diesel
Larry1997 is offline
post #2 of 2 Old 05-29-2014, 06:59 PM
Jon_001's Avatar
Both transmission cooling lines should go to the bottom of the radiator which houses its own little heat exchanger for the transmission fluid. It shouldn't matter which way they go as long as they fit nicely without binding against anything and stay far enough away from the exhaust.
Jon_001 is offline
