UH OH! Transmission Fail - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-03-2014, 02:50 PM Thread Starter
kbostroked06's Avatar
Hello all, new to this so please bear with me. Today while out playing in the snow, I kicked it out of 4WD and put it in 3rd to whip it around in a parking lot. I was going about 15 MPH, and when I pushed it to break loose, it acted as though it kicked into neutral. I let it come to a stop and tried to put it in drive with no response. Reverse gear did nothing, so I popped the hood to check fluid. Fluid level was fine and not discolored. Checked shift linkage and transfer case plugs. Disconnected batteries for a minute and also reprogrammed the truck trying to cover all bases. Got a tow home, truck still wont move, and tow/haul light flashes. Any help or expertise is greatly appreciated.
06 F-250
6.0 w/auto trans
sct livewire with custom tuning from TSD
kbostroked06 is offline
post #2 of 7 Old 03-03-2014, 02:53 PM
Quoted: 385 Post(s)
Feedback Score: 5 reviews
Looks like your tranny fluid pump went out.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
The Following User Says Thank You to Six0~Stroker For This Useful Post:
kbostroked06 (03-06-2014)
post #3 of 7 Old 03-03-2014, 02:57 PM Thread Starter
Also, no prior symptoms. Never slipped or shuttered. I tow on occasion, and it always pulls like a champ. Thanks again!
post #4 of 7 Old 03-03-2014, 06:30 PM Thread Starter
ok so after letting the truck sit for a couple of hours, I decided to give it another shot. Same story as before, but now I have a P0720 code. I have no idea what to think or what to do. I called the guy that did my engine work hoping he could help, but he didn't want to diagnose without seeing the truck. Any ideas??????
post #5 of 7 Old 03-04-2014, 07:47 AM
Quoted: 4 Post(s)
PO720....Output Shaft Speed Sensor.
CT Performance, Inc. is offline
post #6 of 7 Old 03-04-2014, 09:15 AM Thread Starter
The programmer told me what the code relates to, but I'm wondering if the sensor is giving a false reading because of other damage, or will that sensor cause my transmission to act like the it's in neutral in all gears. I'm just puzzled because I still have park, so I know the transfer case isn't stuck in neutral. Or am I wrong?
post #7 of 7 Old 07-06-2014, 07:25 AM
Mine gave up yesterday simular symptoms what did you find?
firetiques127 is offline
