shift cable pops off - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-06-2014, 11:09 AM Thread Starter
Quoted: 2 Post(s)
Tried this in 7.3 trans problems and got no responses was wonderin if anybody has had this problem and could help. I have a 2000 f250 automatic. a week or so went to the store and couldn't shift out of park and the shifter had nothing. crawled under it and the cable had popped of the manual shifter lever on the trans. So i jammed it back on and made it home. Ordered a new cable and installed it (didn't use the procedure i just read about) everything lined up and shifted fine. This is my plow truck and everytime i check it, it's barely on and and i need to jam it back on, i can knock it off the shifter lever by just touching it. Is the locking adjustment tab meant to hold it on? The pin with the depression on it does not appear to be worn(does anyone know the name of that pin?) How hard is it to replace said pin?
2000pstrokeblue is offline
post #2 of 2 Old 01-09-2014, 11:09 AM Thread Starter
Quoted: 2 Post(s)
nobody...bump?
