Transmission flush--now problems - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-19-2008, 12:15 PM Thread Starter
I own a towing company & need some clarification. We have towed 50-60
E450s with automatic overdrive transmissions. Never a problem until today. We always follow the AAA recommend ways to tow vehicles. The manual says these (1998-2006) can be towed from the front without pulling the drive-shaft but with the tranny in neutral with these limitations: Under 35mph & no more than 50 miles. As this is sooooooooo specific and limited, we've always made sure that only my husband performed these tows. Having said that, we were called today that an E450 that we towed to a Ford dealership for an electrical problem has a fried tranny. This is the 4th fried tranny that the same dealership has dealt with in the past 2 months. The one thing in common is that all 4 E450 had a transmission flush performed by the dealership within 12K of the tranny frying. I will pay for a tranny rebuild if this is our fault ($12-1600+/-) but sure don't want to pay if this is poor workmanship due to the transmission flush. Can any of you give me some feedback on this? Thanks in advance.
SMOKINGJOE is offline
post #2 of 9 Old 09-19-2008, 12:19 PM
cchase's Avatar
To be honest, I dont know how a transmission flush would cause it to fail.. unless they took it all the way out and didnt line the TC up right, Can you find out on it what failed? also I would never to from the front with the shaft still hooked, because it is spinning the gears in the transmission without any fuild and its not that hard to roll under and pull out a few bolts. but good luck. and Welcome to the forum!!
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #3 of 9 Old 09-19-2008, 12:29 PM Thread Starter
I have not found out yet what failed but I will because it is going to a tranny shop that I have faith in. We have always removed driveshafts when it is recommended but didn't because we trusted our manual. Big mistake? I don't know. Without going through my records I'm guessing we've towed 60 without pulling driveshaft & no problem with the other 59. I just thought it was strange that all 4 just had tranny flushes!!
post #4 of 9 Old 09-19-2008, 12:31 PM
BRS
Pretty much every auto forum I've ever been on (including this one) had people saying trans flushes free up so much junk in the trans that they start cloggin passages, etc. It's been enough to keep me away from them, but no one has ever produced any concrete evidence. Having put 12k miles on them (don't know timeframe) it will be hard to press the dealer even if they did cause it. But, FWIW I don't know how you can screw a trans flush up from poor workmanship. Good luck.
Ben
BRS is offline
post #5 of 9 Old 10-01-2008, 06:19 PM
yz837's Avatar
Send a message via AIM to yz837
How many miles? Tranny flushes are only supposed to be done on vehicles under 100k miles
2000 F350 7.3L
(sold)
Current Ride:
2000 F350 RCLB
18" mazzi's and 35" nittos
Intake, exhaust, DPtuner
Toy:
1994 2wd 12v Cummins
yz837 is offline
post #6 of 9 Old 10-01-2008, 06:22 PM Thread Starter
I believe it had around 40K on it when flushed. Lasted less than 10K
post #7 of 9 Old 10-02-2008, 04:16 AM
yz837's Avatar
Wow thats really unusual. I could see if it was over 100k, but under 100k not so much. Unless it was really beat on?
2000 F350 7.3L
(sold)
Current Ride:
2000 F350 RCLB
Toy:
yz837 is offline
post #8 of 9 Old 10-02-2008, 05:19 AM
Mark_K's Avatar
That's an old wive's tale. There is no truth to it at all.
A flush CAN screw up a trans if it isn't done right. If they use the wrong fluid the trans can fail in a couple thousand miles, or less. If they didn't ge the level right, either too much or not enough fluid the trans can die.
But free up junk from the flush, you wouldn't say that if you knew how the flush machines work. That doesn't happen.
Mark
Former Ford Automatic Transmission Engineer 1988-2007
Mark_K is offline
post #9 of 9 Old 10-15-2008, 11:15 AM
The thing with towing drive wheels on the ground, is that the internals of the transmission ( planetary gears, sun gear, shell, etc... ) are still turning without the pump moving.
I think 50 miles may be a little short, but we have built many-o-transmissions that were towed that way. It will cause major damage when it is due to lack of lube.
Mike
SVOSHOP is offline
