ZF s5-42 trans problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-17-2008, 05:32 PM Thread Starter
we have a 94 idi 7.3l f-350. recently the transmission started to make a growling noise in 3rd or 4th gear but not in any other gear.we replaced the clutch assembly just before this happened. we got a rebuilt ZF s5-42 manual trans and put it in, but the new transmission makes the same noises as the old one did after just a few miles and a popping noise. I know this can't be good. has any one else had a similar situation? any good ideas how to fix it?
thanks,
Mike
mnicktow is offline
post #2 of 4 Old 07-17-2008, 07:23 PM
dieselknudt's Avatar
Are you sure it was the transmission not a U-joint?
Also the popping sound could be a bearing.
Real Trucks Don't Have Spark plugs!
2005 F350 Lariat 6.0
Crew Cab Long Box FX4
226,000 on the Chassis
New motor at 162K
New transmission at 182K
Cold air intake
4" Exhaust
dieselknudt is offline
post #3 of 4 Old 07-18-2008, 06:25 AM Thread Starter
I have had the truck on a lift and driven it. it's not in the driveshaft or u-joints
it is coming from the transmission I think the rebuilder didn't replace all the bearings in the trans or didn't get a C clip installed correctly on the main shaft.
mnicktow is offline
post #4 of 4 Old 10-16-2013, 10:35 AM
any updates
Did you figure out what was causing the problem?
89F350 is offline
